Thread: Transmission upgrade
Results 1 to 20 of 28
  1. #1 Transmission upgrade
    SE Level Member king04305's Avatar
    Sep 2011
    MIAMI, FL
    Thanx in advance for whoever replies with help
    I have 2005 grand prix with 24 inch rims,on it...,yes im fully aware their bad for the car. However they arent coming off, also I drive the car pretty aggressive... My first transmission lasted 122 thousand miles. So I ll say probably about 15 thousand with the wheels on. In the near future the car will have a rocker, plog, downpipe setup hopefully running e85... Looking to find out what tranmssion upgrads I,can do to extend the life of my currwnt transmission
  2. #2 Re: Transmission upgrade
    Dec 2012
    Where 4T65E's were born
    Just throw a cooler on it to start. The reason bigger wheels are harder on it, is because you're basically changing the ratio. So it's harder for 1st gear to get the car moving. It being harder, makes the torque converter work harder(creating more heat) You need to be able to disperse more heat, so a cooler is a good idea. Especially if you're a maniac.
    Sold.
  3. #3 Re: Transmission upgrade
    trans cooler and shift kit will help a lot.
  4. #4 Re: Transmission upgrade
    Sep 2011
    MIAMI, FL
    Where could I get a transmission cooler from?
  5. #5 Re: Transmission upgrade
    Dec 2012
    Amazon or Ebay. Advance auto does sell them too(pricey). Search Hayden cooler. You'd probably want the 404
    Sold.
  6. #6 Re: Transmission upgrade
    I'm dealing with a few too many other cars currently, can't remember if all GP's were 3.29 if they aren't charged or not. If you aren't supercharged, you may be able to change the differential (and programming) to lower your gear ratio and help it out. That with a cooler and shift kit in the accumulator I'd think that's about all you can do on the current to help it.
  7. #7 Re: Transmission upgrade
    Sep 2011
    MIAMI, FL
    What if I were to go built transmission? Or would make more sense to do these upgrades on the current on?
  8. #8 Re: Transmission upgrade
    Aug 2011
    'Merica
    If you go built go with TEP (Triple Edge Performance)
    http://www.tripleedgeperformance.com/
  9. #9 Re: Transmission upgrade
    There's plenty of upgrades you could do if you were having one built.
    I'd start off with saying TEP would likely be your best builder. They take the time to talk to you and understand your ideas/goals then match trans upgrades etc to your build. I'm not aware of many others that do that.
    In that case, I'd automatically say.. look at your tire size and how much % it's different than stock and consider making up some of that with a gear ratio change. Afterall the manufacturer uses many different variables in building our cars and the biggest single things they do in the trans to mediate less power, larger tire size, etc are torque converter stall and gear ratio.
  10. #10 Re: Transmission upgrade
    Sep 2011
    MIAMI, FL
    Is this something that could be addressed in a custom dyno tune?
  11. #11 Re: Transmission upgrade
    Wouldn't need a dyno tune to get that stuff straightened out just a tune after the gear ratio change.
  12. #12 Re: Transmission upgrade
    Right... ^^^ what Smutster said
  13. #13 Re: Transmission upgrade
    Sep 2011
    MIAMI, FL
    So to change gear ratios.... Can u do tgat on current trans or,must I,have a built trans? Any other company than TEP?
  14. #14 Re: Transmission upgrade
    You could do it yourself with the right tools. First is to check what ratio you have currently. Then consider what is available. I know that diffs are available in ratios like 2.86, 3.05 and 3.29. If all GP's are 3.29, then you are out of luck. If your car is a 2.86 or 3.05, you can pull the passenger axle, pop the diff and sungear out, replace them with a higher ratio and put the axle back in. Reprogram for the change in ratio along with your tire size and be done. This requires a programmer and some basic tools.
  15. #15 Re: Transmission upgrade
    Aug 2011
    'Merica
    My 05 GT n/a has 3.05 so I assume since he is SC then it would be the 3.29
    Easy way to find out is call dealer service desk and tell them what you are looking for and give them your VIN. They will be able to tell you what ratio you have currently
  16. #16 Re: Transmission upgrade
    Where's it show he's sc?
    Being SC, the diff would already be a 3.29 and a trans rebuild would need to be done to change the overall ratio. SC has 1:1.121 drive/driven gear ratio plus the 3.29 that makes it a 2.93 overall. Not charged transmissions have a 1:1 ratio in the drive/driven.
  17. #17 Re: Transmission upgrade
    Aug 2011
    'Merica
    His other thread said that he is SC. The thread where we are bashing him for running such big wheels....
    http://www.grandprixforums.net/showt...t=83350&page=4
  18. #18 Re: Transmission upgrade
    Sep 2011
    MIAMI, FL
    Yes i am supercharged. a rebuild isnt such a bad thing seeing as i plan on keeping the car. I am going to try and save the the current one as much as possible with the transmission cooler and a shift kit. However im guessing whatever builder i use needs to understand to change the ratio for the wheels, also going to upgrade input shaft for the additional power i plan to have... Correct? Setup I will be running is plog/downpipe/rockers hopefully running e85 as well?
  19. #19 Re: Transmission upgrade
    Only the comp g sc cars had 3.29
  20. #20 Re: Transmission upgrade
    You mean only the Comp G's were SC'd with drive/driven gear ratio of 1:1? All the SC aka HD transmissions had a 3.29 diff.
    King.. what you could do to rebuild while your still driving is have a non hd trans rebuilt with all the upgrades etc, then toss your HD diff and diff cover into it. Presto, insta 3.29 overall ratio because the non hd has the 1:1 ratio
  1. upgrade help!
    By speed demon in forum General Tech Discussion
    Last Post: 03-13-2013, 08:02 AM
  2. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  3. PCM Upgrade
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-26-2010, 12:34 AM
  4. What to upgrade next?
    By DBGP in forum General Tech Discussion
    Last Post: 10-25-2009, 09:40 PM
