Thread: Transmission=Done
Results 1 to 10 of 10
  1. #1 Transmission=Done
    SE Level Member SLO-6's Avatar
    Aug 2008
    Texas
    Today, my tranny went out!
    Its only been about an hour so Im not 100% sure on the details. But none of the gears work, including Park!!! When in Park my car continues to roll (if on incline). When in Neutral, car in completely normal, no clicking noises or jerks. When in Drive or lower car doesn't budge, when I give it gas, gears spin making clicking like noise.
    Reply back if you have had this problem before or have any experience that may be related to or like the one I have described.
    Thanks,
    SLO-6
    Eaton M90 S/C, Thrasher Engineering CAI (soon a FWI By: TDC RACING, MSD Wires. ZZP 3'' Stainless Catback Exhaust, Northstar TB KIT, ZZP 3.4 Pully Swap
  2. #2 Re: Transmission=Done
    Barksdale AFB, LA
    Trans shift cable not set properly?
    2009 Subaru Impreza WRX STI
  3. #3 Re: Transmission=Done
    Aug 2008
    Texas
    Honestly I couldn't tell you anything about my transmission. Never had a problem before.
  4. #4 Re: Transmission=Done
    Barksdale AFB, LA
    The fact that park doesn't work, and no other gears work, leads me to believe that it's something wrong with the shifter cable or the selector bracket on the trans itself. Park is pretty much fool proof. Just a rod and a pawl that jams into a gear.
  5. #5 Re: Transmission=Done
    Jul 2008
    sumter,south carolina
    that happened to me when i broke one on my axles,same symptoms.but i think u would know if u broke one.
    02 GTP with mods 05 GP for DD
  6. #6 Re: Transmission=Done
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    If the diff is bad it wont have park either-that is if the spider gears are broken or apart. Basically no park when in park position-you SHOULD manually check this by verifying the shift arm on the case IS in park position- will be a problem between the diff and the wheels which will include the differential, output shaft, cv joints-axles.
  7. #7 Re: Transmission=Done
    Aug 2008
    Texas
    Quote Originally Posted by Trannyman95 View Post
    Ha i had a Tranny Pro check it and from what i described to him he said its a CV AXIL/ Joint issue (OIL ALONG FINDERWELL ON RIGHT SIDE)
  8. #8 Re: Transmission=Done
    Jul 2008
    good deal...should be a cheap fix.get the shaft,they are pretty easy to put in.
  9. #9 Re: Transmission=Done
    Aug 2008
    Texas
    yea put them in and turns out that somehow my undercarriage was bent causing this problem
  10. #10 Re: Transmission=Done
    Jul 2008
    damn dude thats no good,is it fixable?
  1. how do i remove the transmission
    By EMerola in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 12-09-2008, 07:28 PM
  2. Transmission Diagram?
    By Quicklynx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-25-2008, 06:21 PM
  3. GM Transmission Information
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-23-2008, 01:00 PM
  4. Transmission Solenoids
    By japslpr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2008, 04:13 PM
  5. Transmission questions.
    By ChvyTrcksFrdScks in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2008, 07:11 PM
