Thread: Question about hard shifts, trans mounts and additives
Results 1 to 9 of 9
  1. #1 Question about hard shifts, trans mounts and additives
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    So I got a pan drop, filter and intense shift kit installed, which was great, and shift much better and firmer, now with the addition of my overkill pcm, its pretty ridiculous.. the 1-2 shift at WOT makes it shift so hard it sounds like its clunking, 2-3 is a little better but not much.. Nothing seems like its wrong, but the trans feels like its shifting to hard for the motor, in a sense.. So Im gonna check the trans mount today, ( even tho when it had the shift kit put in a few weeks ago, he said it looked good and there is no leaks ) .. But Are there good solid mount ( trans or motor ) that wont vibrate the piss out of the car inside? Just ttrying to 'tighten up' I guess you could say , what feels like is alot of movement under the hood..
    And are there any good additives to put in the fluid? Amsoil, Lucas etc
    And on that topic of additives, Has anyone ever used Redline Water Wetter? If so Im guessing its ok for use with all coolants?
    Red Line Water Wetter - Coolants & Antifreeze - Fluids & Chemicals - SoloMotoParts.com - Motorcycle Parts, Accessories and Gear
  2. #2 Re: Question about hard shifts, trans mounts and additives
    Did will know you had a shift kit?
    The line pressure is likely too high.
    Just use a quality synthetic transmission fluid.
  3. #3 Re: Question about hard shifts, trans mounts and additives
    Nov 2012
    MN
    Will did know I had a kit when they dropped the pan for dex6 and a filter.
    Also when it shifts at higher rpms 5500+ I feel a slight vibration. Not sure what that is either but it feels like it comes from the rear. Like the suspension possibly? Cuz it does sag pretty good in the rest when I get on it
  4. #4 Re: Question about hard shifts, trans mounts and additives
    Not to mention intenses kit are pretty firm. Well a lot firmer then trans go kit.
    04 Comp G.
  5. #5 Re: Question about hard shifts, trans mounts and additives
    Nov 2012
    MN
    I think I told will it was a trans go. Not sure if he would adjust for the 2 different kits, but this is way harder shifts than my SSei , which I know for a fact was trans go. I'll have to find my receipt
  6. #6 Re: Question about hard shifts, trans mounts and additives
    I would imagine the line pressure would be different since the Intense kit it firmer then the trans go but I'm not a expert when it comes to transmissions!
    04 Comp G.
  7. #7 Re: Question about hard shifts, trans mounts and additives
    I had my line pressure pretty much maxed out on my 98 with a thrasher shift kit. I liked it.
  8. #8 Re: Question about hard shifts, trans mounts and additives
    Your input shaft didn't I'll bet.
  9. #9 Re: Question about hard shifts, trans mounts and additives
    230k miles and it didn't complain
  1. Engine / Transmission additives? (More for trans)
    By Silver2kgtp in forum General Tech Discussion
    Last Post: 03-16-2013, 11:21 AM
  2. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  3. 98 GTP, Trans lossing 4th gear sometimes, shifts hard and slips into 3rd.
    By shawnooohhh in forum General Tech Discussion
    Last Post: 02-11-2012, 10:44 AM
  4. Shifts hard when hot.
    By JWillas92 in forum General Tech Discussion
    Last Post: 06-02-2011, 09:50 AM
  5. Hard shifts
    By dbextreme in forum General Tech Discussion
    Last Post: 02-13-2010, 09:09 PM
