Thread: rpm's varies witn cruise on
Results 1 to 14 of 14
  1. #1 rpm's varies witn cruise on
    Aug 2016
    wi
    Ok Scottydogg, what would cause this? Cruise control Module? 1999 Grand Prix GT. Shut the cruise off and the rpm's stay normal. When cruise is on the rpm,s vary.
  2. #2 Re: rpm's varies witn cruise on
    no idea. lol
  3. #3 Re: rpm's varies witn cruise on
    Aug 2016
    wi
    Scotty you failed me. Thought of you guys as soon as the kid called. Guessing something to do with cruise control module. Anybody else with a thought?
  4. #4 Re: rpm's varies witn cruise on
    Cruise control is what it says it is, all it will try to do is maintain a steady speed.
    With that comes times when the rpms will fall as it closes the throttle for coasting and then opens it again to maintain the set speed or accelerate to reach that speed again. Often it will even go 1 mph above the set speed and let it fall back to the set speed.
    It's much easier to maintain rpm with your foot.
  5. #5 Re: rpm's varies witn cruise on
    hangover park IL
    There is a different torque converter clutch control scheme when in cruise control.
    ~James~ Psychotic Gearhead
  6. #6 Re: rpm's varies witn cruise on
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    How much variance? Cruise control isn't too much. Usually not enough to make an audible difference.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  7. #7 Re: rpm's varies witn cruise on
    Aug 2016
    wi
    He said it will vary 600 to 700 rpms with the cruise on. It climbs up and then goes back to normal.
  8. #8 Re: rpm's varies witn cruise on
    Sounds like it's downshifting to 3rd then if the rpm jump is that much.
  9. #9 Re: rpm's varies witn cruise on
    Aug 2016
    wi
    Ok, Had him downshift it when the rpm's start to vary. It downshifted to 3rd. Is there a clutch pack?
  10. #10 Re: rpm's varies witn cruise on
    Newnan, GA
    So its struggling to stay in 4th?
  11. #11 Re: rpm's varies witn cruise on
    This doesn't sound mechanical if everything works great outside of cruise control.
    Makes me wonder if the CC box itself is screwy.
  12. #12 Re: rpm's varies witn cruise on
    Aug 2016
    wi
    He said it is doing in drive now too.
  13. #13 Re: rpm's varies witn cruise on
    Sounds like the 4th gear hub is stripped now.
  14. #14 Re: rpm's varies witn cruise on
    Jan 2014
    AR
    Hmm. This sounds like the GTP complaint I had a long time ago. Of course cruise varies TP, thats it's job. To give whatever throttle position keeps it closest to the set speed. Includes downshifting.
    I was advised here that the surging I was experiencing might be relative to high humidity. It would start to chug or buck as I would call it, going up gentle hills on cruise while the trans tries to stay locked up and in O/D as long as it can. Tap gas and it downshifts into 3rd. I was also advised here that it sounded like the hub in the trans had gone bad.
    My solution was to use only Shell gas and to keep it in 3rd until the speed limit is 50. The cruise can do a better job of holding your speed down when coasting if its in 3rd, and driving in 3rd doesn't hurt anything that I know of. On very humid days, the stock tune just does this or so I was told. By Bill. Its true. Humid days can make you feel this. Good gas lessens the effect by producing a little better power from the same throttle. My trans wasn't bad. It only had a few thousand miles on it. Just relating my experience with a similar complaint, not second guessing anybody
  1. Cruise KR, and a lot of it.
    By DanPrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2015, 03:30 PM
  2. Replies: 2
    Last Post: 04-28-2014, 02:07 PM
  3. Little day cruise
    By fri3dchick3n in forum General Grand Prix Discussion
    Last Post: 04-15-2013, 10:35 PM
  4. ac temperature varies from drivers side and passengers
    By rickbaker in forum General Tech Discussion
    Last Post: 09-02-2010, 11:20 AM
  5. cruise
    By brad360 in forum General Tech Discussion
    Last Post: 06-19-2010, 03:32 PM
