I'm working on a 98 Regal GS with an Intense Tranny (installed less than 1000 miles ago). It has 3.69 gears and one of those SRC's wired up to the PCM. I was thinking about removing the SRC and just tuning the PCM for the 3.69's.
Using a spreadsheet I found I have the following set with the PowerTuner:
Stock 30-tooth reluctor
Calculated_Pulses_Per_Revolution: 28.03
Pulses_Per_Mile: 22710
Drive_Sproket_Ratio: 0.89
Now I imagine I need to drop all the Shift and TCC MPH settings by 22-25% (multiply current values by .78-.75).
Am I correct? I emailed Intense (to find out what reluctor they used) and Scott Cook strongly recommend against doing this.....but I'd like to get more input first before believing his recommendation.
It gets a P1811 from time to time and I was thinking that removing the SRC would rule it out as a culprit.
