Thread: Intense gen 3 LSD
Results 1 to 5 of 5
  1. #1 Intense gen 3 LSD
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Anyone have any experience on durability etc of these on higher hp builds? +-400whp turbo car. Looking at getting one but I know some of the LSD's have been hit or miss in terms of durability. I don't want something that is going to explode and take out my trans, but some extra holding power on the front wheels would be awesome for traction and torque steer etc I would expect. Thanks for any insight!
  2. #2 Re: Intense gen 3 LSD
    I would suggest getting a GM Torsen or Quaiffe if you want an LSD. The Intense ones were hit and miss. I personally went through 3 in a short time and wasn't up in the high power like you are going for. My last one..FWIW was rock solid. But ....it took a few to get to that point.
  3. #3 Re: Intense gen 3 LSD
    Lorain, OH
    what happened to the 3 that you went through? any trans damage or just not holding? I am not ready to spend the 2k on a quaife or torsen diff...
  4. #4 Re: Intense gen 3 LSD
    Jan 1970
    Maquoketa, Iowa
    I recall Tim King replying to a similar thread but over in clubgp about the intense diffs, I believe he said something along the lines that stock was better. lol
  5. #5 Re: Intense gen 3 LSD
    First time I noticed it because the car wouldn't move unless it was turned off and restarted. Then it would move briefly and stop engaging again. This was because when the diffs go, they often self destruct. Fill the pan with diff soup. Not that you want it to happen, but the only good thing is the diff fluid goes right into the pan and is filtered before it goes anywhere else. This usually means that if you grenade a diff, you can pan drop, replace filter, diff and if needed the diff cover.
    I learned this after sending the trans back to Intense and Tim went back through it. The next time or two, I sent just the diff back in to be redone again.
    The offending Gen 3 LSD
    Some marks from the pieces rolling around it.
    Some of the debris around the pin down in the diff
    Diff cover with VSS still in it.
    More of the diff guts in the pan
    And the filter that saves the rest from metal soup, definately has a glitter look to it.
    Cut away shot to see where things are located
  1. Intense PCM?
    By Freddy in forum PCM Tuning
    Last Post: 05-13-2012, 09:35 PM
  2. Intense G8 GT
    By UR LOSN in forum Other Vehicles
    Last Post: 10-11-2010, 09:08 AM
  3. Looking to buy a Intense PCM
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 12-02-2009, 09:59 AM
  4. Intense PCM
    By JB Miller in forum General Tech Discussion
    Last Post: 05-14-2009, 10:45 AM
  5. Intense MPS vs. ZZP MPS
    By 04CompG in forum General Tech Discussion
    Last Post: 10-07-2008, 05:03 PM
