Thread: 4T65e - slipping at start. Buick Terraza 2005
Results 1 to 2 of 2
  1. #1 4T65e - slipping at start. Buick Terraza 2005
    Mar 2013
    Katy, TX
    Hello, everyone!!! I'm new here, hoping you, guys can advice me little bit!
    I read a lot information, but, unfortunately, couldn't find the answer.
    The problem showed up 5000-8000 miles ago: Transmission was shifting really hard between all gears, slipping on first gear from start for couple seconds then getting "kick" and van starting move normally. All symptoms when tranny is hot(after 20-25 min drive).
    What I've done: 1000 miles ago changed transmission fluid and filter. Fluid pan had normal "mud" around magnet without metal particles. I got good improvement- all "kicks" got much more lighter. Anyhow few days later put my van for diagnostic at transmission shop. Result of diagnostic: P1811 and from 2200-3000$ for rebuild tranny . Took van home, ordered TransGo Shift Kit and 300 miles ago I installed it by myself(of course again changed filter, fluid).
    Result: Shifting perfect between all gears(cold, hot - no difference), but slipping on fist gear, just when tranny is hot, almost every second start, yes, some starts is perfect. If put lever to D1 no slipping.
    I desided to measure line pressure thru transmission port and I've done it today, after 25 minutes of driving:
    P,N,R - 60 PSI
    D4, D3, D2 - 45 PSI
    D1 - 125 PSI.
    I don't want to rebuild transmission, may be there is less expensive way to fix the problem???
    Buick Terraza 2005 CXL 95000mi
    Buick Century 1999 Custom 37000mi
  2. #2 Re: 4T65e - slipping at start. Buick Terraza 2005
    Jan 2012
    Canada
    If it doesnt slip in D1 then its most likely a forward apply band, these vans like to eat transmissions my sv6 is on its 3rd with only 55k miles on it.
    2001 GTP Special Edition - 3.29's built tranny, Coilovers with agx struts, 04+ seats, 18" Eagle 077's, Ported heads, ported blower, pacesetters, 3.4"
    2004 BMW 325CI with the sport package and the correct amount of pedals.
  1. a start year for better 4t65e hd builds from gm?
    By Shiftingshaddow in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-06-2013, 09:46 PM
  2. 4T65E 1999 GrandPrix SE Slipping in 1st
    By socalchlln in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2010, 04:07 PM
  3. Odd Shifting from start: 2-1-2-3-4 (4T65E-HD)
    By tigers2007 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-09-2008, 11:10 AM
