Thread: gear set, 4th gear hub, channel plate gouged! help!
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: gear set, 4th gear hub, channel plate gouged! help!
    That's where the teeth of the clutches sit. From what I can see..they look ok.
    Greg, not saying you don't have a point. At the same time though..to me it's kinda like replacing a side cover cause theres a scratch on it. Not structural, not hurting or touching any surfaces (now lol) ... shouldn't be an issue.
  2. #22 Re: gear set, 4th gear hub, channel plate gouged! help!
    SE Level Member kawasaki22106's Avatar
    Ford City, Pennsylvania, United States
    ok good!!
    665whp 584ft lb torque
    93 pump fuel+meth on 26psi
  3. #23 Re: gear set, 4th gear hub, channel plate gouged! help!
    Toss up a better pic of the marks.. I may side with Greg on the replacement if they look deep. Like he said.. too cheap of a part to skimp.
  1. tranny wont shift into 3rd gear. please help where is my 3rd gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2012, 11:49 AM
  2. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    Last Post: 11-12-2012, 12:18 PM
  3. Channel plate gasket
    By bull40dawg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-27-2012, 08:27 PM
  4. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
