Thread: Reverse Servo Cover
Results 1 to 6 of 6
  1. #1 Reverse Servo Cover
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    So I put in a trans into my car. Only replaced the chain. I turn my car on them go to shift it throw the gears. When I put it in reverse the servo cover snap ring popped and the cover blew off.
    Why would this happen? Is it worth putting back on and trying again or should I just say F it.
    97 Bonneville SE Not so much a 97 anymore
  2. #2 Re: Reverse Servo Cover
    Johnstown, NY
    I'd say check the snap ring groove. If it's good I'd say just put it back together and hope for the best. If its gouged out with not enough "catch" area, you might need a new tranny.
    98 Red Coupe Grand Prix GTP : 180* T-stat, U-Bend delete, NGK TR55's, SLP Catback
    My Ride: http://www.grandprixforums.net/jevik...upe-73301.html
    A must read for modding: http://www.grandprixforums.net/safel...0-a-67580.html
  3. #3 Re: Reverse Servo Cover
    Nov 2009
    Central Jersey
    Yeah the previous owner said he may have not seated it right.
  4. #4 Re: Reverse Servo Cover
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Reverse servo is a PITA to get the snap ring in. I would say that it wasn't not seeded all the way down or the snap ring fully in the groove. I have a hard time picturing that grove becoming damanged or worn out. I'd say try again and make sure that the snap ring is sitting exactly where it's supposed to be.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  5. #5 Re: Reverse Servo Cover
    Previous owner pulled that ring to show Max how tough it was going to be to inspect his in the car. Was pretty sure we had it back in place. Super sorry about that buddy.
  6. #6 Re: Reverse Servo Cover
    Nov 2009
    Central Jersey
    No problem actually went in pretty easy. Was able to use the exhaust manifold as leverage to push down the cover.
  1. Vacum line for brake servo
    By stevenlukacs77 in forum Introductions/Noob Questions
    Last Post: 06-26-2012, 04:14 AM
  2. Reverse Out - Servo Lip Seal?
    By BoilerTom in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-10-2011, 07:28 PM
  3. Reverse Servo Help!
    By nj346 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2011, 08:29 PM
  4. leaking fluid from reverse servo assembly
    By slimtechgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2010, 04:53 PM
  5. Need some help on the Reverse Servo Seal.
    By Raz97GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-29-2009, 07:19 AM
