Thread: Aluminum Transmission Pan?
Results 1 to 10 of 10
  1. #1 Aluminum Transmission Pan?
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
  2. #2 Re: Aluminum Transmission Pan?
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Depends in your application. Race car.... sure. Otherwise just get the Dorman stock replacement pan with a drain plug. You can find them for under $40 shipped.
  3. #3 Re: Aluminum Transmission Pan?
    Mar 2013
    Colorado - USA
    I got one. I wish I'd shopped around. There's one available on ebay that is very similar but has two extra fins and a threaded boss for a temp sensor. My ZZP pan was not flat at all. I checked it on a surface plate it was as wavy as a Pringles chip. It did lay flat after I bolted it onto the trans, I guarantee that it's not good for the gasket though.
    It does seem like it will function well as a fluid cooler - lots more area compared to the steel pan - and the fins hang down in the breeze under the speeding car.
    I'll keep you updated about trans temps when I finally drop in my new trans. I bought it to counter the extra heat I expect to make with my TCI torque converter.
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  4. #4 Re: Aluminum Transmission Pan?
    Arizona
    Quote Originally Posted by jlgp2007nc View Post
    Good lookin on that piece the pan is 27 bucks w/drain plug off rock auto part # 265814
  5. #5 Re: Aluminum Transmission Pan?
    May 2008
    Schuyler, NE
    Quote Originally Posted by rodguezsciii View Post
    No. The worlds fastest FWD 3800 ran a modified stock pan.
  6. #6 Re: Aluminum Transmission Pan?
    Sep 2012
    the question is for an item used to cool down tranny temps....I'd prefer it over a regular tranny cooler....
    Quote Originally Posted by Shmoke View Post
    sweet....keep me updated....
  7. #7 Re: Aluminum Transmission Pan?
    Sep 2012
    ....bet it was never daily driven on hot summer days in bumper to bumper traffic either....
  8. #8 Re: Aluminum Transmission Pan?
    Sep 2012
    North Carolina
    Installed my Dorman pan today at work with no issues. New filter and gasket as well. The pan doesn't come with a drain plug gasket and doesn't seem to need one, but I just threw one in for the hell of it. Free shop supplies haha. Dex VI in abundance as well so I can drain and fill as much as I want!
  9. #9 Re: Aluminum Transmission Pan?
    Sep 2012
    the plug on the pan is a + ....but last year I saw some pretty hot tranny temps, and wanted to know if anyone else has had success with the Aluminum pan....
  10. #10 Re: Aluminum Transmission Pan?
    Jan 2009
    Tallahassee, FL
    If you're worried about trans temps just get a cooler. It'll do more than a pan will.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  1. Aluminum Oil Pan
    By ls1camino in forum General Tech Discussion
    Last Post: 08-10-2012, 04:36 PM
  2. M90 is it aluminum?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 07-03-2010, 12:27 PM
  3. Aluminum Transmission Pan?
    By SlowNA06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2010, 02:09 PM
  4. Aluminum oil pan
    By quiksilvergt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 12:45 PM
