Thread: External transmission filter?
Results 1 to 9 of 9
  1. #1 External transmission filter?
    Feb 2013
    Missouri
    Hey everyone,
    I'm wanting to make my transmission last as long as possible, the odometer has 228,000 on it now. The transmission shifts fine as it is, and the fluid is red (not bright red, but red), and not burnt looking\smelling at all. My plans are to add another cooler, drop the pan, change the filter, and install the "medium" shift kit described here:
    Grand Prixs Of North America • View topic - DIY Shift Kit For Under $10*
    One thing I was curious on is an external transmission filter. What I have done in the past with good results is use one of these:
    Perma-Cool Remote Oil Filter Brackets 1791 - SummitRacing.com
    with
    WIX Filters Transmission Filters 495-51622 - SummitRacing.com
    I plumb it into the cooler line, and change that filter every few oil changes. I've done it with my 1989 F150 and a few of my friends trucks with great results, it's all the craze at FSB (Fullsizebronco.com), as well. I was thinking on installing this while my engine was out, what do you guys think?
  2. #2 Re: External transmission filter?
    Arizona
    Wix is what I got in the future though I might go with the oil filter style ones however I've read nothing bad about wix trans filters I have mine double clamped with fuel injection clamps. And lock wired so the lines could never pop off.
  3. #3 Re: External transmission filter?
    Feb 2013
    Missouri
    I was thinking of running something like that, but I was hoping to find something a bit more friendly when I goto change it. My concern is the micron rating on the filter I posted, it's 28. Seems a bit high for what I want. I was doing some reading over at Bobistheoilguy and from what I read, 5 micron is best. Hell, even my normal oil filter for my l67 is 17 micron. I ended up going withe a FL1A filter (which is stock for my 5.0 in my truck) on my truck, which is a 20 micron filter.
    Here's a pic of the setup I have on my truck. I know that B&M says to mount the cooler upside down, but this is how Ford mounted these cooler stock (this one is off of a E350 van). You can see the top of the filter mount down on the frame rail:
  4. #4 Re: External transmission filter?
    Arizona
    Its easy to change my filter just remove the headlight and its right there lock wire isn't a problem
  5. #5 Re: External transmission filter?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    When I did my TEP swap, I was planning on bypassing the radiator cooler all together and do a setup like this.
    http://www.summitracing.com/parts/bc...FVJp7AodGXEAkg
    Also I am going to add an external "oil" type filter similar to this. But not sure which one yet.
    BD Diesel Performance Inline Transmission Filter Kits - JEGS
    I'm interested to know if anyone on here has used an external filter, what they used, with pics!!
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  6. #6 Re: External transmission filter?
    Feb 2013
    Missouri
    Damn, Thats an expensive set, I just use something like this:
    http://www.summitracing.com/parts/hda-214/overview/
    With this filter:
    http://www.summitracing.com/parts/wix-51622
    From what I've heard, bypassing the radiator cooler is a bad idea, because in colder weather, it actually helps warm up the transmission. Adding a cooler is fine (and I intend to) though.
  7. #7 Re: External transmission filter?
    Arizona
    I had the wix but decided to with the summit racing b&m kit Now. If your that guy that does burn outs and high-speed maneuvers on a cold engine/trans then you should keep Tue factory cooler in the loop if you live somewhere really really reallly cold otherwise standalone will work just fine winter or summer. I've been running that way since 08' never a issue. And I've lived in ga Colorado and arizona
  8. #8 Re: External transmission filter?
    Nov 2009
    Tennessee
    Thanks, that's exactly what I was looking for just didn't look hard enough.. LOL!!!! I hadn't searched much for the inline filter kits, that was just one I found... But the cooler I had is similar to what I want... Where I live it doesn't get cold cold.. I mean freezing at night yea but rarely below 20 and daytime temps are usually above freezing.. My winters are "mild". I have also heard the pros vs cons of having an external trans cooler, I'd just like to keep it separate!!!
  9. #9 Re: External transmission filter?
    I live here. DirtDog's Avatar
    Jun 2012
    Heck especially during the winters I always let the car idle for at least 30 seconds to get everything flowing...dunno if it makes a difference or not. But when its cold cold out my dad always told me to let it warm up some before driving
  1. How to add an external range pnp switch to a transmission
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 09-05-2016, 07:12 PM
  2. 2004 Comp G transmission Filter.
    By Iceman83 in forum General Grand Prix Discussion
    Last Post: 02-24-2013, 07:48 PM
  3. Inline transmission filter
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 10-19-2012, 07:42 PM
  4. Tips on getting the new transmission filter in?
    By foghelmut in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2011, 10:41 AM
