Thread: pulling apart
Results 1 to 14 of 14
  1. #1 pulling apart
    Mar 2013
    Georgia
    Hello everyone. 02 grand prix, sounds like spun bearing noise in park and neutral. Goes
    away when you put it in gear but does not move, does not move in reverse either.
    Took passenger side of tranny off pulled out final drive gear assembly. And took a few other things
    out. One question is. The aluminum housing I took off, there is metal stuck around the
    vss. Where the seal is, right behind that I believes there is suppose to be a bushing
    there. I need to know if one is suppose to be there, also I don't think that would
    be the reason it won't go in gear
  2. #2 Re: pulling apart
    Sounds like you broke the drive chain.
  3. #3 Re: pulling apart
    Mar 2013
    Georgia
    The drive chain is on the driver side under valve body.
    Do you think it would make noise in all gears? Just trying to
    get a good understanding. I took off the passenger side housing
  4. #4 Re: pulling apart
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    If you have metal sticking to the VSS that is in the passenger side diff housing you have a much larger failure inside of the transmission. You have a bearing that has failed in the transmission. You'll be needing a rebuild my friend.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  5. #5 Re: pulling apart
    Apr 2011
    Columbus, OH
    Because of your description that the noise goes away while the car is in D or in Reverse those are the only times that the drive chain is not moving. That would lead me to believe that the stator support bearing or the driven sprocket support bearing has failed. When either one of them goes they usually take out a lot of other things. A full rebuild is in your very near future.
  6. #6 Re: pulling apart
    SE Level Member sdogg201's Avatar
    Mar 2012
    Saginaw
    Just go to the local junk yard around 250 for another trans unless you want to spend to have it rebuild.
  7. #7 Re: pulling apart
    Mar 2013
    Georgia
    Well thanks for all the insight. I am thinking of a rebuildnot sure yet. I am gonna post a few photos of what I got done so far.
  8. #8 Re: pulling apart
    Mar 2013
    Georgia
  9. #9 Re: pulling apart
    Mar 2013
    Georgia
  10. #10 Re: pulling apart
    Mar 2013
    Georgia
    Does any one notice the bright aluminum mark. It is on all of you
    the inner bolt holes. Meaning bolts go in the housing from the outside. Almost
    like slapping up against them. Any suggestions on that issue.
    Also where can I buy a housing ready to install
  11. #11 Re: pulling apart
    Apr 2011
    Columbus, OH
    I see where you are taking about with where it looks to be rubbing. Have you inspected the differential itself yet? Checked to see if the tolerance is within spec? Reluctor wheel on the diff hasn't walked it's way toward the passenger side a bit?
    I wouldn't worry about that little damage to the housing.....no need for going out and buying a replacement.
    Long story short, if you car isn't moving in when you put in driver or reverse there is a much larger issue going on in the trans....even with taking off and inspecting the diff there is not much you're going to be able to do without digging into it further. The transmission is going to need a full rebuild. A JY trans is typically the cheapest option at this point unless you rebuilt it yourself.
  12. #12 Re: pulling apart
    Mar 2013
    Georgia
    I got ya. But what I am wondering also, is, in the bore of the housing
    should there be a bearing or bushing there. It looked to be rubbing inside
    of the bore and found a long strip of metal about 2 and a half inches long
    maybe sixteenth wide. Stuck it to magnet and it stuck. So I'm sure its not aluminum.
  13. #13 Re: pulling apart
    Take a look at the trans/info post I posted. There are pictures of the assembly and that will tell you if something is missing. Either the selective washer and bearing are on the diff or they are missing. That won't stop you from going into gear. And the amount of shavings on the VSS are 100% completely normal. When you wipe it..there will be a fine paste. If you have chunks, that's bad.
    I'm in agreement, it sounds like something broke on the input side of things. Maybe an input shaft, TC or chain.
  14. #14 Re: pulling apart
    Mar 2013
    Georgia
    I can't find your post would like to see it
  1. Pulling Oil pan?
    By woodoggie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 02:38 PM
  2. pulling under WOT
    By JESSEGOTTA GP GT in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2011, 08:22 AM
  3. Pulling the AC
    By protoplayer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2011, 09:53 AM
  4. Pulling my engine
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2009, 01:07 PM
  5. FWI without pulling the bumper.
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 05-14-2008, 08:35 AM
