So I tried going under the transmission section but it said no new posts so I hope this section is ok. I have been reading threads on this forum for a while but this is my first post. I have a 2007 grand prix gxp with 88,000 miles on it. I have had some issues with the tranny when taking off from a stop when it goes from 1-2 for a while 6-8 months now but have just been babying it due to lack of money. When I take off from a dead stop (not fast or babying it) just little slower than normal when it gets to the top end of 1st gear and I can tell it should shift to 2nd the rpms just go up and if I dont let off the gas it will clunk into 2nd gear, if I let off the gas a little bit it will shift fine. I have kept track of my transmission temps when it does this and the coldest ive seen it do it is 118° and the warmest it 186°. I took it to a guys shop I work with and he said grand prixs are know for this tranny problem but its normally every gear 1-2 2-3 3-4 mine is only 1-2 and it doesnt do it all the time just randomly. Sometimes it will do it once a day and sometimes 5-10 times just driving to work. The shoo gave me an estimate of $900 to go through all the cylinoids and replace then as well as replacing the valve body. He.wasent convinced this needed done though bc its only doing it in 1-2 not all the gears. He told me lets try to do a flush, drop the pan, and replace the filter and see if this helps, also replaced with Dexron VI fluids. So I had everything flushed and filter replaced today and it still did it to me once driving home from picking my car up from the shop. Please Help idk what to do now.
