I have a 2003 Grand Prix 3.8 (K vin, no super charger) when I was changing the trans filter and replacing the leaking pan gasket I noticed oil on the air deflector. After further inspection I notice that the lines running to the trans cooler are leaking where the steel meets the rubber. One is leaking rather badly not sure if the other is leaking. I plan on replacing both since I already have to fill the trans.
My question is how do they connect to the trans and the cooler? It looks like they are just a hex nut with a flare or compression under it. Is that correct? Is there a trick to removing them? Anything else to watch out for while changing them?
Thanks for your help!
