Thread: Odd feeling shifting out of park etc
Results 1 to 15 of 15
  1. #1 Odd feeling shifting out of park etc
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    okay dont know to much about trannys when i go from park to rev it goes smooth and then feels like it grabs it hard and kinda rocks the car before i take my foot off the brake and does the same thing from reverse to drive and park to drive and just resently when i put it in to drive it did it then when i went to push on the gas it paused and then caught and went its only done it once and ive driven it since but hasnt done it the car has been drivin hard, quick starts, and running at high speeds its been drivin at 105 mps for 20 min before a few times ive since backed off and been nicer too it lol
  2. #2 Re: Tranny Problem
    Travis.. likely your motor mounts are bad.
  3. #3 Re: Odd feeling shifting out of park etc
    Jan 2013
    leavenworth ks
    some one else was telling me that my motor mounts being loose can also be the reason i went through so many plastic coolent elbows i went through 3 or 4 of them in like 3 months. they other day i was reving the engine a bit to try and warm it up a little and it was feeling like i rocked the whole car when i did it so i did it a little harder to make sure it wasnt wind or something and it deffently rocked the car so i think it is possible my motor mounts are going bad ive done the mod that is under easy mods to do i turned the rubber squares in the top motor mounts btw my car is an 04 gp gt2
  4. #4 Re: Odd feeling shifting out of park etc
    pop the hood and shift it back and fourth, have a friend do it while you watch. my engine was moving a good 4 inches and flexing more i bet with the mounts blown. it used to jump hard when shifting it from p to r then d
    also look for the engine to twist some in the bay when in reverse i think it was.
    what mine looked like, you can see the bar in the mount, and the U bend bar under it that bolts to the engine. it was all free moving.
    the rest of it.
  5. #5 Re: Odd feeling shifting out of park etc
    Tell the guy that said your motor mounts might be related to your coolant elbows that ....is pretty much impossible.
  6. #6 Re: Odd feeling shifting out of park etc
    Jan 2013
    leavenworth ks
    lol okay bill. btw i kept snaping the upper elbow the lower one was always fine then when i switched my tensioner pully it came with new gm elbows so i used those and they didnt snap for over 3 months and then got alluminum ones. Okay so is that a lower engine mount? btw it looks like something took a **** on it but i see what you were talking about. im going to go try watching as some one shifts for me
  7. #7 Re: Odd feeling shifting out of park etc
    sounds like the elbows are not being put in right, holes not cleaned well or misaligned. try metal elbows next time. ive dont mine 2 times, once cause it was leaking, then again when i did my lim, not problems yet either time. used plastic both times.
    no way the mounts is causing the elbows to break.
  8. #8 Re: Odd feeling shifting out of park etc
    Jan 2013
    leavenworth ks
    mine are good right now metal ones are going in in the spring when it warms up and i think it was cause i wasnt able to get the holes cleaned all the way of the rtv
  9. #9 Re: Odd feeling shifting out of park etc
    RTV is not the best way really.
    lube the O rings with some oil, slide them in a good clean hole. <<< man that sounds dirty lol
  10. #10 Re: Odd feeling shifting out of park etc
    Jan 2013
    leavenworth ks
    okay so how much movment should the engine have when it shifts
  11. #11 Re: Odd feeling shifting out of park etc
    not a whole lot if the mounts are good.
    with bad mounts mine was doing some moving. like a lot.
  12. #12 Re: Odd feeling shifting out of park etc
    Jan 2013
    leavenworth ks
    mine was very noticable when i shifted and reved it
  13. #13 Re: Odd feeling shifting out of park etc
    Jan 2013
    leavenworth ks
    were are the lower mounts at
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  14. #14 Re: Odd feeling shifting out of park etc
    Jan 2013
    leavenworth ks
    any help would be amazing
  15. #15 Re: Odd feeling shifting out of park etc
    this is a vid for the trans mount in a regal, same deal really. your may look a bit different tho. this is a 3 part vid. the motor mount is done the same way.
  1. Have a feeling this is sposed to be plugged in someplace. Help Please!
    By burgundybullet in forum General Tech Discussion
    Last Post: 08-17-2012, 11:31 AM
  2. How much of a "clunk" do you get shifting from park?
    By Hippo Machine in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-24-2011, 09:53 PM
  3. Intermittent flat tire feeling..
    By genocide in forum Brakes/Suspension/Chassis
    Last Post: 03-23-2011, 11:48 AM
  4. Feeling pretty anxious : )
    By AmericanRiceEater in forum Off Topic Discussion
    Last Post: 07-27-2010, 12:32 PM
  5. I have a feeling this can't be good..
    By mr2stig in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2009, 11:21 AM
