Thread: 02 GTP tranny swap
Results 1 to 6 of 6
  1. #1 02 GTP tranny swap
    Jul 2014
    Virginia
    My forward band broke in my '02 GTP and I'm wondering 2 things:
    1. I found a used '02 trans from a non-GTP, can I make this work in my car?
    2. Could I use the parts from the non-GTP to fix my trans?
    Short on cash and need to get my car running asap to get to work.
  2. #2 Re: 02 GTP tranny swap
    GTP Level Member speed demon's Avatar
    Apr 2011
    MICHIGAN
    Just swap the differential from your trans to the non supercharged one and you should be golden.
    '01 GTP: Rebuilt Trans by Andrew S....300m,hardened 4th,Transgo shift kit,V8 chain ect ect,3.8 MPS,ZZP 10.5.....More to come!
  3. #3 Re: 02 GTP tranny swap
    Jul 2014
    Virginia
    Is it only the differential and passenger side axle that need to be swapped out?
  4. #4 Re: 02 GTP tranny swap
    Apr 2011
    MICHIGAN
  5. #5 Re: 02 GTP tranny swap
    If you swap the diff only, the gear ratio will be different. This may or may not throw a code.
  6. #6 Re: 02 GTP tranny swap
    Feb 2013
    Missouri
    I'd say swap out the gears (driven gears) on the new transmission so that way the ratio's match. While you are in there, I'd put a hardened set of chains (off a GXP) and a hardened 4th shaft in. I only say this because it is 100000x easier with the transmission out of the car, lol.
  1. HD tranny swap
    By TimMcCallum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2014, 07:29 AM
  2. Tranny swap
    By Nsane in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-17-2010, 06:06 PM
  3. 2.8 l tranny swap tp a 3.1
    By avaitors in forum General Tech Discussion
    Last Post: 09-15-2009, 01:33 PM
  4. tranny swap
    By kbradley in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2009, 04:59 PM
  5. pcm help with tranny swap
    By ddyke2000 in forum PCM Tuning
    Last Post: 05-03-2009, 01:41 PM
