Thread: jerk or shudder sometimes when sitting at stoplight?
Results 1 to 20 of 21
  1. #1 jerk or shudder sometimes when sitting at stoplight?
    Donating Users
    Oct 2012
    lake city,fl
    not sure if anyone else has experienced anything like this or not i have a 2004 grand prix gt has 136000 miles on it original motor and trans just did a trans filter and new fluid about 6000 miles ago issue being this sometimes after starting off from a stoplight the car will jerk like its popping into gear but doesnt do it all the time i was wondering if bad cv axles could cause this, im not a hundered percent sure but i think it does more when i stop harder. or worst case internal problem in the tranny ? all other gears fine no slipping same with 1st gear 90% of the time no problem any input is greatly appreciated
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    You should get the trans scanned for codes.. If it has a p1811 it will need a pressure control solenoid common problem on the 4t65s. The pressure control solenoid has pretty random symptoms when there is a problem with it
  3. #3 Re: jerk or shudder sometimes when sitting at stoplight?
    Donating Users
    Oct 2012
    lake city,fl
    thanks, so i wont get a check engine light or anything just symtoms like that ? and how expensive or hard is that to do any special tools needed im pretty mechanically inclined
    Jul 2012
    Kansas city
    Sometimes they don't set the check engine light your year I think don't any newer usually do set a check engine light when that's the issue. It's kind of a choir you have to hang the left side of the cradle way down and take the trans side cover off to get to it once you have the cover off its one bolt and connector and done just the side cover is the rough part. Parts are only about 125 at the dealer..
  5. #5 Re: jerk or shudder sometimes when sitting at stoplight?
    Donating Users
    Oct 2012
    lake city,fl
    sounds like day of fun getting to it if thats the problem but anyways thanks a bunch , o one more ? is it something that an autozone reader would pick up on?
    Jul 2012
    Kansas city
    Yea it would be a good days job with out a lift or shop. I doubt it but you could try. Might have to swing by a tranny shop like amacco I think they pull codes for free
  7. #7 Re: jerk or shudder sometimes when sitting at stoplight?
    Donating Users
    Oct 2012
    lake city,fl
    ok thanks definetly gonna check into that
    Jul 2012
    Kansas city
    No problem
  9. #9 Re: jerk or shudder sometimes when sitting at stoplight?
    GT Level Member bsharpminor's Avatar
    Mar 2012
    Minnesota
    Figure anything out?
  10. #10 Re: jerk or shudder sometimes when sitting at stoplight?
    Donating Users
    Oct 2012
    lake city,fl
    well finally got to a tran shop in my area had it scanned and nothing so i really dont know now and its really spontanious when it happens actually hasnt happened in awhile i was really hoping i would get something but it did not throw any codes.
    and i was gonna update sooner but my laptop crashed and i just got it back up and running but thanx for checking back anyway
  11. #11 Re: jerk or shudder sometimes when sitting at stoplight?
    Mar 2012
    Minnesota
    I just found this: No Forward Cold
    I've had a similar kind of thing, that you've described, happening very sporadically when it's been cold. Not as bad as in the article, but it feels like it's slipping and slams into gear.
  12. #12 Re: jerk or shudder sometimes when sitting at stoplight?
    Donating Users
    Oct 2012
    lake city,fl
    thanks for that link that is interesting, so basically it comes down to a rebuild in the end to correct the problem
  13. #13 Re: jerk or shudder sometimes when sitting at stoplight?
    SE Level Member Kikasscuda's Avatar
    Feb 2013
    New York
    i have the exact same issue, always curious about it, when i accelerate slower off a stop it doesnt happen, moderate accel to heavy mayb 15% of the time
  14. #14 Re: jerk or shudder sometimes when sitting at stoplight?
    Donating Users
    Oct 2012
    lake city,fl
    yea its seems like if i let my foot off the brake and let it roll a bit then go it seems fine so idk
  15. #15 Re: jerk or shudder sometimes when sitting at stoplight?
    Feb 2013
    New York
    Quote Originally Posted by davidadams View Post
    I also have an upgraded pcm from zzperformance and one of the specs says-torque abuse modes are modified to eliminate bog at launch..i believe it also firms up the shifts at each point.. I'm not sure if this is what its referring to or not but it still feels like it firmly catches into 1st gear and it shouldn't have to catch 1st gear at all you would think because it should automatically be in 1st gear when at a stop.
  16. #16 Re: jerk or shudder sometimes when sitting at stoplight?
    Jul 2014
    Illinois
    Has anyone ever fixed this scenario without replacing the whole trans? Mine is doing this exact thing and I am curious if it's as simple as changing something like a solenoid or if the problem is internal.
  17. #17 Re: jerk or shudder sometimes when sitting at stoplight?
    Donating Users
    Oct 2012
    lake city,fl
    I changed the trans filter and put a quart of Lucas in the new fluid and never had it happen after that
    Sent from my MB865 using Tapatalk
  18. #18 Re: jerk or shudder sometimes when sitting at stoplight?
    Jul 2014
    Illinois
    ok, looks like I'll try that. thank you sir
  19. #19 Re: jerk or shudder sometimes when sitting at stoplight?
    Jul 2014
    Illinois
    Did you use the fluid conditioner or the trans fix?
  20. #20 Re: jerk or shudder sometimes when sitting at stoplight?
    Trans slip version
  1. Creak and a jerk.
    By mteschGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2012, 06:23 PM
  2. road rage jerk having a bad day.
    By BlackGT97 in forum The Rant Forum
    Last Post: 09-25-2011, 06:56 PM
  3. GT VS GTP stoplight 2 stoplight
    By 02PrixGT in forum Track Sessions and Kills
    Last Post: 08-01-2010, 03:43 AM
  4. How she's sitting right now!
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 03-10-2010, 04:37 AM
  5. 94 3.1 shudder
    By stevirebel in forum Introductions/Noob Questions
    Last Post: 11-02-2009, 03:12 PM
