Thread: Change Chain+Sprockets With Trans In Car?
Results 1 to 20 of 34
  1. #1 Change Chain+Sprockets With Trans In Car?
    Oct 2011
    Puyallup WA
    Hey been tossing around switching over to 2.93 gears wondering if it is possible to get to the chain and sprocket with the trans still in the car. Searched and didn't find anything specific to this. Thanx for any input Toby
    08 G8 GT - exhaust Tune
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    So you have a compg and you want to downgrade it essentially?
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: Change Chain+Sprockets With Trans In Car?
    Oct 2011
    Puyallup WA
    I wouldn't consider it downgrading...just want the longer gears for hwy drivin
    Oct 2011
    MI
    Yeah I was reminded why you would want mpg as I drove down the hwy earlier running 80 lol
    Oct 2011
    MI
    I'm sure the pcm would have to be programmed for the different gear ratio?
  6. #6 Re: Change Chain+Sprockets With Trans In Car?
    Oct 2011
    Puyallup WA
    Yeah I talked to a friend of mine and he said it would be a PITA to do in the car...and yes would have to plug in new gear ratio vie HPT
  7. #7 Re: Change Chain+Sprockets With Trans In Car?
    May 2008
    Schuyler, NE
    You can do it, but it's a huge PITA. You would probably be time ahead if you just pulled it out.
  8. #8 Re: Change Chain+Sprockets With Trans In Car?
    The biggest issue is the input shaft. You'd need to get the ring off it to pop the new gear on and I'm not sure how far into the TC it's going to want to slide. Otherwise..the writeup I did on 4th clutch hub is the depth you'd go.
  9. #9 Re: Change Chain+Sprockets With Trans In Car?
    Portland Oregon
    Easy to do. I say that because I've dropped that cradle side many times for valvebody work.
  10. #10 Re: Change Chain+Sprockets With Trans In Car?
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    I was wondering if I was the only one that had that same thought. I have a CompG trans in my GT(P) and I'm not too happy with the fuel economy I'm getting out of it. Might be a swap in my future as well.
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  11. #11 Re: Change Chain+Sprockets With Trans In Car?
    Oct 2011
    Puyallup WA
    Thanx for the input guys! Will be reading bills writeup!
  12. #12 Re: Change Chain+Sprockets With Trans In Car?
    You guys may laugh, the minute I got 3.29's I missed the highway life of the 2.93's. Now I'm rolling along in the L26 with 2.93's in the trans.
    Bonnies came with a 2.86 and an NA motor. You'd never win a race from a stoplight, you'd pass every gas station once you found the highway.
  13. #13 Re: Change Chain+Sprockets With Trans In Car?
    Oct 2011
    Puyallup WA
    Yeah I was completely unaware that my GTP was a CompG when I bought it...now I know and very unhappy with MPG but I like the rest of the car!
  14. #14 Re: Change Chain+Sprockets With Trans In Car?
    Apr 2011
    Vassar, Mi
    I did a regear on mine in the car. Super simple, just about anyone could do it. Take the snap ring off the input shaft and pull the sprocket off, input shaft doesnt go anywhere. I went the fun direction though lol (2.93 to 3.29)
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  15. #15 Re: Change Chain+Sprockets With Trans In Car?
    Jun 2013
    Hollywood ,FL
    How bad could.your gas mileage really be with 3.29 what rpm are you at on highway
  16. #16 Re: Change Chain+Sprockets With Trans In Car?
    Oct 2011
    Puyallup WA
    I average 25mpg freeway and 18 city most people with 2.93 get 28
  17. #17 Re: Change Chain+Sprockets With Trans In Car?
    28 hwy?
    04 Comp G.
  18. #18 Re: Change Chain+Sprockets With Trans In Car?
    Oct 2011
    Puyallup WA
    Yeah my friends 99 gtp gets 28hwy has gotten 30 couple times...mine has gotten 26 1 time most the time it's 24 25
  19. #19 Re: Change Chain+Sprockets With Trans In Car?
    Not bad never really bothered keeping track of mine. One of those cons of owning a Comp G. I just learned to deal with it and tell myself you didn't buy a Prius what do you expect.
    04 Comp G.
  20. #20 Re: Change Chain+Sprockets With Trans In Car?
    Oct 2011
    Puyallup WA
    I was expecting what my friends gtp gets and had no clue I was buying a comp g lol I came from a Subaru world and had no clue what the competition group emblem meant hahah
  1. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  2. To change trans fluid or not?
    By Elite6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-11-2011, 10:08 AM
  3. How much Fluid for Trans Filter Change
    By dhdolphns in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2011, 03:48 PM
  4. 01 gtp Trans fluid change
    By Draco in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2011, 07:38 PM
  5. Possible to change drive/driven sprockets in-car?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2008, 03:18 PM
