Thread: Wal*Mart Super Tech Transmission Fluid
Results 1 to 20 of 38
  1. #1 Wal*Mart Super Tech Transmission Fluid
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    I've decided to stay with Dex III in my 01 GT, I'm replacing the filter and adding the TransGo shift kit this weekend. So I was in Wally mart and picked up 2 gallons of SuperTech Multi-Vehicle ATF, the jug says it "Meets the performance requirements of Dexron, Dexron II, DexronII-E, Dexron III, Mercon, and Mercon V."
    In addition:
    Super Tech Multi-Vehicle Automatic Transmission Fluid provides excellent protection against wear and shudder resistance.
    Super Tech Multi-Vehicle Automatic Transmission Fluid:
    Excellent protection against wear and shudder resistance
    Resistant to thickening due to high temperatures
    Friction stability to maintain smooth consistent shift performance
    Anybody use this stuff? Good, bad or indifferent?
  2. #2 Re: Wal*Mart Super Tech Transmission Fluid
    SuperCrap.
    I only use SuperTech anything when I'm running it for a few minutes just to drain out later.
  3. #3 Re: Wal*Mart Super Tech Transmission Fluid
    It works.
  4. #4 Re: Wal*Mart Super Tech Transmission Fluid
    Ohio
    its on the gm recommended list
  5. #5 Re: Wal*Mart Super Tech Transmission Fluid
    Go to their website and check the MSDS to see who manufacturers it.
    Then decide if you want a cheap mix of their product.
  6. #6 Re: Wal*Mart Super Tech Transmission Fluid
    SE Level Member harner's Avatar
    Apr 2012
    New Ringgold, PA
    Never used it for a reason. Good luck.
    1998 Grand Prix GT Sedan - SOLD
    10 Camaro 2SS/RS | 94 TA | 87 IROC | 06 Silverado 1500
    Wouldn't use it personally. I would either use Ac delco or you could find Castros Dexron III for a decent price I think around $35-40 on amazon and use prime shipping if you have a account.
    04 Comp G.
  8. #8 Re: Wal*Mart Super Tech Transmission Fluid
    Dec 2008
    ****'s Creek
    Quote Originally Posted by harner
    What's the reason?
    Quote Originally Posted by 99PGPGT
    If it meets the spec, what makes it inferior?
    Here's what Valvoline says about their MaxLife:
    MaxLife DEX/MERC ATF contains a blend of superior base oils and a unique additive package to help extend the life of transmissions with over 75,000 miles. It is formulated to maximize transmission performance, reduce transmission wear, and improve and maintain smooth shifting longer than conventional fluids. MaxLife DEX/MERC ATF is compatible with new and rebuilt transmissions and will not void new car warranties.
    Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and LV, Allison TES 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
    Is it possible that one fluid can meet all of those specs? I know very little about this and am trying to understand better.
  9. #9 Re: Wal*Mart Super Tech Transmission Fluid
    Apr 2012
    New Ringgold, PA
    The last time I looked into it, Walmart basically went with the lowest bidder for that product, I just don't remember off the top of my head who it was. I think the MSDS should reveal that.
    I'd much rather spend a couple dollars more for a quality product in the weak link of the drivetrain.
  10. #10 Re: Wal*Mart Super Tech Transmission Fluid
    I've used it numerous times with no problems. It works fine. Add a bottle of lucas while you're doing it.
  11. #11 Re: Wal*Mart Super Tech Transmission Fluid
    GTP Level Member buickman104's Avatar
    NYC
    I use the super tech stuff. I also know Billboost does too.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  12. #12 Re: Wal*Mart Super Tech Transmission Fluid
    Dec 2008
    ****'s Creek
    Got the Lucas additive ready to go too.
  13. #13 Re: Wal*Mart Super Tech Transmission Fluid
    Jul 2011
    B-Town, PA
    my 97 deville and my 99 PAU both lived exclusively on Super Tech synthetic oil and trans mission fluid their entire life until the 4T80-E in the deville went Dex VI. I put about 80k HARD miles on that cadillac and it never once gave an issue til the headgaskets went (as happens in ALL northstars) and the body on the PAU rotted out before i had a chance to beat that into the ground...
    if it meets the standard...it's good to go. some are better than others but if it says DexIII it's good enough for GM so it's good enough for me.
    SMGPFC Member # 569 - Mad Monkey Approved!
    New Ride - 2012 CTS-V Coupe 6spd - Black/black, Recaros. Stock for now.
  14. #14 Re: Wal*Mart Super Tech Transmission Fluid
    walmarts fluid is the same as travelers brand, sold by tractor supply. they are both made by Warren performance products, the bottom of the jug should have a WPP in the mold of the jug/quart.
    im using travelers brand currently in my used tranny. been a year now, and the fluid is still as red as the day it went in. tranny is just fine too. knock on wood.
    at the end of the day, look it up, its good fluid.
    this would be their site. Warren Distribution - Since 1922 - Omaha, NE if you google them you'll find bob the oil guy talking about them as well.
  15. #15 Re: Wal*Mart Super Tech Transmission Fluid
    SWPA
    Its not that WalMart goes with the lowest bidder, WalMart can purchase so much stuff and have it made private label so they get it cheaper. It could have easily been Havoline, or Valvoline in a different bottle and you guys would call it crap just because it is the WalMart brand.
    For the longest time Advance Auto's brand of oil was Havoline, but some people would not use it because it was not "name-brand."
  16. #16 Re: Wal*Mart Super Tech Transmission Fluid
    Dec 2008
    ****'s Creek
    Thanks guys, will hive it a try and report back. Have Trannyman on speed dial as a back up.
  17. #17 Re: Wal*Mart Super Tech Transmission Fluid
    New York
    As noted, Walmart can purchase it far cheaper than anyone else and sell it for less as a private label. If it is Dex III/IV, whatever, it meets GM's standard. You are good to go. Probably more important to the tranny life is not the fluid brand but changing it often (every 25-30 K miles with a new filter) and keeping it cool (run a tranny cooler). The 4T65E will last a long time doing those 2 procedures.
  18. #18 Re: Wal*Mart Super Tech Transmission Fluid
    That's pretty excessive.
  19. #19 Re: Wal*Mart Super Tech Transmission Fluid
    Dec 2008
    ****'s Creek
    The SuperTech trans fluid added 20HP and 25 lt-lbs of torque output, and it looks like fuel mileage is up about 5 mpg.
  20. #20 Re: Wal*Mart Super Tech Transmission Fluid
    Dec 2008
    ****'s Creek
    Just kidding! Would be nice though, wouldn't it? I went ahead and used the WM stuff, will report on how it lasts. Trans does run good though, of course some of that is the shift kit and Lucas.
  1. transmission fluid
    By Linebacker in forum General Tech Discussion
    Last Post: 05-17-2012, 08:25 AM
  2. super tech dex vi
    By 2005gt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2011, 12:42 PM
  3. transmission fluid
    By dave2002GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2010, 09:01 PM
  4. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
  5. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
