Thread: Installed transgo shift kit, worked for a week, pcs problem back
Results 1 to 12 of 12
  1. #1 Installed transgo shift kit, worked for a week, pcs problem back
    Aug 2012
    ohio
    I had the whining sound and harsh shifts associated with the pressure control solenoid problem. Installed a transgo shift kit, after reading all the great reviews and people saying it solved their problem. My 99 intrigue shifted great for about a week, and today the problem came back. Is this normal, for the shift kit to work for a little while then not help anymore?
    Could it be the stored code in the computer making it whine and shift harsh again? I'd really appreciate any thoughts or suggestions, I can't have my transmission go out!
  2. #2 Re: Installed transgo shift kit, worked for a week, pcs problem back
    Usually when people say it "fixed" their problem it didnt... Its just a quick fix for the time being that works for some but not for everyone...
    Hate to say it but assuming it was installed right, gonna be time for a new tranny...
  3. #3 Re: Installed transgo shift kit, worked for a week, pcs problem back
    Ontario
    When you have a PCS issue, depending on how far along it is, a shift kit is a bandaid fix.
  4. #4 Re: Installed transgo shift kit, worked for a week, pcs problem back
    Aug 2012
    ohio
    Quote Originally Posted by gtpsleeper View Post
    A new tranny? That's the worst possible outcome. Replacing just the solenoid wouldn't work?
  5. #5 Re: Installed transgo shift kit, worked for a week, pcs problem back
    whining sounds usually points to a clogged filter. you did change that when you dropped the pan? right?
  6. #6 Re: Installed transgo shift kit, worked for a week, pcs problem back
    Ontario
    Quote Originally Posted by z99intrigue View Post
    The solenoid replacement cost is almost more or very similar to the cost of a junkyard tranny. As stated by Scotty, did you change the filter as well? I'm pretty sure the kit comes with the new filter and gasket.
  7. #7 Re: Installed transgo shift kit, worked for a week, pcs problem back
    Aug 2012
    ohio
    Yes, changed filter and added new fluid to replace what came out of the pan. This was the first time since that it acted up. I came home, and left again about 15 minutes later- no problems whatsoever. Im hoping it was just a fluke, prior to it shifting hard I had been sitting in stop and go traffic for a while, so maybe that was what did it.
  8. #8 Re: Installed transgo shift kit, worked for a week, pcs problem back
    New York
    Did you read my post on this issue?
    http://www.grandprixforums.net/4t65e...ion-25211.html
    If you truly only have a PCS issue ( and not other problems) the transgo shift kit AND the installation of a cooler of some sort OUTSIDE of the radiator cooling (the tranny cooler does all the cooling) will solve the issue. I now have 30,000 miles on my 4T65E since the Transgo shift kit and the installation of (2) 18,000 GVW double stack Long Coolers (36,000 GVW capacity) and have not have a hard shift issue once. The tranny has been perfect!
    Change the tranny fluid and filter often (I change mine every 25-30,000 miles or every 3 years) and keep it running COOL. Heat kills ALL transmissions. I also have 2 extra magnets in the pan to collect more metal particles. At the last tranny change, the pan was clean-like new.
  9. #9 Re: Installed transgo shift kit, worked for a week, pcs problem back
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    could just change pcs, pretty sure they are cheap and not that hard to replace, or buy a used a tranny and fix this one then you got a spare that's what I was going to do but I stored it a friends shop... then his shop went bankrupt along with my old tranny lol.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  10. #10 Re: Installed transgo shift kit, worked for a week, pcs problem back
    New York
    The PCS switch is relatively cheap but it is NOT easy to replace since there is no access to it from either under the car or from on top-the engine cradle has to removed and the whole transaxle dropped down to access the PCS solenoid. It is a big job and very expensive if you have to pay someone-easy $600-800. For about $100, the transgo shift kit and cooler is a steal and WILL cure the problem PLUS it is much better for the transmission to run cooler outside of the hot radiator-translation longevity.
  11. #11 Re: Installed transgo shift kit, worked for a week, pcs problem back
    you can change the pcs while its in the car.
  12. #12 Re: Installed transgo shift kit, worked for a week, pcs problem back
    New York
    You can as stated above but it is NOT easy.
  1. Transgo Shift Kit Install Help
    By matthew911 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-15-2012, 06:22 PM
  2. Transgo Shift Kit, 1st to 2nd Slower Then Stock? Help!
    By HiLuckyB in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2012, 02:19 AM
  3. transgo shift kit install Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2012, 11:19 AM
  4. Those that have installed the transgo kit
    By Merlin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-14-2009, 11:54 PM
  5. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
