Thread: Transmission Cooler
Results 1 to 15 of 15
  1. #1 Transmission Cooler
    SE Level Member nukkinfuttz's Avatar
    Sep 2012
    Richmond Va
    I want to add an external trans cooler this weekend. Whats a good size to get? They get more and more expensive the larger they get, so i want to be sure i buy the one i "need" and not one for a cummings diesel or something rediculously large. Any recommendations?
    91BerettaGTZTurbo=Holset HX-35,26PSI,Bored,EagleRods,WisecoPistons,O-rigned,TitanCopperHG, adj Cam Gears,Custom turbo mani,TurboSmart36mmWG,Screamer Pipe,Custom 3"turboback,MSII-E, LC1Wideband, PyroMeter,KnockSense,Walbro 255LPH,75lbs/hr inj's,3"Core42"Wx15"T IC,HKS BOV Waterinjection,antilag,6puckClutch,Slicks, just needed a Part Number
  2. #2 Re: Transmission Cooler
    25 000 "lbs" or btu would be nice if you're replacing the stock cooler.
    15 000 if you're adding in series.
  3. #3 Re: Transmission Cooler
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    I got mine from Checker auto parts, it is cheaper HERE. I used the "678" model rated for 24,000LBS and bypassed the cooler in the radiator. Now my trans and engine both stay cooler even in stop and go.
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  4. #4 Re: Transmission Cooler
    I live here. DirtDog's Avatar
    Jun 2012
    could you upload pictures of how you mounted your trans cooler?
    Dec 2010
    DMV
    Interested as well.
    May 2011
    United States
    Yeah I could, give me a minute. Actually a good time cause I already have my bumper off.
    Sent from my Droid
    May 2011
    United States
    Sent from my Droid
  8. #8 Re: Transmission Cooler
    I thought you weren't supposed to mount them like that.
    BM says you're not supposed to as well: http://bmracing.com/wp-bnmcont/uploa...er_techdoc.pdf
    May 2011
    United States
    Thats to prevent an air pocket i guess, ive never seen that. It works fine
    Sent from my Droid
  10. #10 Re: Transmission Cooler
    Dec 2011
    Southern Wisconsin
    David at TEP installed mine that way too, no issues so far and a nice cool trans. I have about 6k on Dave's trans, fluid still smells and looks like it just came out of the bottle.
  11. #11 Re: Transmission Cooler
    GT Level Member ls1camino's Avatar
    Laurel, MD
    After attaching the lines and clamps, but before mounting it to the radiator, turn the engine on and let the fluid circulae while holding he cooler in one of the recommended positions.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  12. #12 Re: Transmission Cooler
    New York
    That's exactly as my (2) 18,000 GVW coolers are mounted, one on each side-no issues for 30,000 miles now! I installed my first trans cooler in 1978 on a Nova SS and besides my GP have a Long 24,000 GVW cooler on my 94 Mustang GT Convertible now for 14 years with zero issues. It is fine mounted that way. BTW-Have never had a trans failure running the cooler outside of the radiator.
  13. #13 Re: Transmission Cooler
    anecdotal evidence.
    so convincing.
  14. #14 Re: Transmission Cooler
    New York
    Some of the trans experts might want to read this for some "anecdotal evidence":
    How often should the automatic transmission fluid... — Yahoo! Autos
    The trans fluid in my GP runs about 135 degrees in the summer and about 145-150 degrees on the Mustang GT with the coolers mentioned above-both running outside of the radiator-the coolers do ALL of the cooling.
    Jun 2012
    On my GXP the stock tyranny temp was round 220 in the summer but I added two extra coolers to it and now it stays in the 170 range. They help alot
    Sent from my DROID RAZR using Tapatalk 2
  1. Transmission cooler line
    By jhnnyboz in forum General Grand Prix Discussion
    Last Post: 08-24-2012, 08:03 AM
  2. Transmission cooler lines
    By jakeb157 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-01-2011, 12:09 PM
  3. Transmission Cooler Lines
    By tdm571 in forum The Rant Forum
    Last Post: 02-27-2011, 07:17 PM
  4. transmission oil cooler
    By 03buickregalls in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2010, 09:11 PM
