Hi,everyone I have 2000 GP and it's leaking fluid from pressure relief valve on the top of tranny;it's not overfull, can anyone please explain to me what's going on with my tranny,THANKS IN ADVANCE!
Likely you blew a channel plate gasket and therefore fluid is pushing up and out.
If I'm right, you'd need to do the below to get at it. While you are there.. if it's a 97-03, I'd swap the 4th hub shaft at the same time.
http://www.grandprixforums.net/how-t...ess-54448.html
