Thread: Trans Leak
Results 1 to 13 of 13
  1. #1 Trans Leak
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    i wasn't really sure where to post this.
    Alright i am having a problem with my transmission fluid leaking and have already checked the pan gasket and that is all fine and since i have never really done anything drive tran wise i was wondering if it could be caused by my cv axle been popped out ? i checked the seal and it is good, also i have a vibration at highway speeds here are some pics below
    Passenger side :
    FWI i already know that the drivers side is suppose to look like it is popped out but i am unsure if this is how the passenger side is suppose to look
  2. #2 Re: Trans Leak
    Oklahoma
    I cant say with a lot of certainty since its been a while since Ive looked at mine, but it is possible that the CV shaft can induce some vibration, Ive been down that road and it is possible that if that seal is bad that some tranny fluid is going to get out. Pull that shaft out to replace it and you can loose about a half a quart of fluid.
    I do believe that seal can be replaced in the car (i.e., not having to pull the tranny) but for any definitive answers regarding the tranny I'll defer to Trannyman as he is the resident expert in these matters.
    I'll also move this to the tranny section since it deals with that.
  3. #3 Re: Trans Leak
    Barksdale AFB, LA
    A bad inner passenger side CV joint causes vibration when accelerating during turns as well as vibration at speeds from 60-70MPH.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Trans Leak
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    It looks like you have an engine oil leak that is making everything pretty messy in the area. Is the leak that you have definately red trans fluid? It is not very often to see an axle leak on these transmissions unless the seal is damaged or the axle shaft is damaged or worn and the only way to verify that is to take things apart and inspect. I would get some brake-clean and spray everything off really good so it is dry and clean and then drive the car again to see where the wet areas are to find the leak
  5. #5 Re: Trans Leak
    St. Louis
    i already checked it out and it wasn't oil some was dripping onto the trans pan it is was red colored and then i tasted it and the only area the seems to have this fluid around it is where the half shaft goes into the transmission i need to replace my CV axle anyways so i guess while i am doing that i should just go ahead and change that seal
  6. #6 Re: Trans Leak
    Oklahoma
    Quote Originally Posted by stlmo_gtp View Post
    Wait!! Did you really just say you 'tasted' it?
  7. #7 Re: Trans Leak
    St. Louis
    yea, it's not like you drink it or anything you just put a little dab on your finger and then touch it to your tounge it's not harmful or atleast i don't think so
  8. #8 Re: Trans Leak
    GTP Level Member Scimmia's Avatar
    QCA, IA
    If that's harmful, I'm in trouble. First time I changed my filter, I had to really pry on it. It popped off and landed in the drain pan, splashing trans fluid all over my face. I can attest to the fact that it doesn't taste too good.
    2001 Buick Regal LS - Almost Stock
  9. #9 Re: Trans Leak
    St. Louis
    Quote Originally Posted by Scimmia View Post
    lol its not suppose to taste that great
  10. #10 Re: Trans Leak
    Banned
    New Port Richey Florida
    Change the cv shaft and the axle seal but be careful when installing the new seal use some kinda of a real light lube to aid the seal in seating all the way and DON'T pound on the seal matting surface thats aluminum and it could crack.
  11. #11 Re: Trans Leak
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    that is real funny
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  12. #12 Re: Trans Leak
    Jan 2009
    Eagan Minnesota
    I have a similar leak on the passenger side. And it is a mess just as well. It appears to be the inner Axle/ CV seal but the way is drips down the side housing then off the pan it almost appear like the side housing is leaking. If this is the case can the seal or gasket inside that case be replaced while replacing the axle seal ? While it's in the car ? It leaks at a rate of a pint or two a month. Too cold here to replace it now but I want to be prepared for a nice warm day . Damn it was 30 below yesterday !
  13. #13 Re: Trans Leak
    Jan 2009
    Eagan Minnesota
    Oops. I guess thats the differential housing, I found a few diagrams of the Transaxle and a procedure to install a limited slip differential. I don't need one but I need to fix this leak, maybe it's just the Oring seal seeping or something more troubling.
    Thanks!
  1. Motor Oil Leak!
    By TMOTA503 in forum General Tech Discussion
    Last Post: 08-21-2008, 10:20 PM
  2. masive oil leak
    By AKGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2008, 09:40 AM
  3. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
  4. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
  5. Oil leak
    By fiveinthelive in forum General Tech Discussion
    Last Post: 03-11-2008, 09:35 AM
