Thread: Installing Transgo SK4T65E shift kit - need help with valve body removal (side case)
Results 1 to 5 of 5
  1. #1 Installing Transgo SK4T65E shift kit - need help with valve body removal (side case)
    Apr 2012
    Windsor, Ontario
    I am in the middle of installing a Transgo shift kit on my '04 GT and I could use some help with the valve body removal process - specifically, which bolts do I remove first? I called Transgo and they recommended I purchase a Service Guide but that's a few days away and the car is all apart right now. I searched the web but it appears most people only install the parts that go inside the bottom pan. While I have it apart to change the EPC solenoid I would like to put the entire kit in.
    Has anyone documented which VB fasteners come out first or could someone possibly scan me a couple of pages out of a service manual? I am also in need of the correct fastener torques.
    Appreciate any help.
  2. #2 Re: Installing Transgo SK4T65E shift kit - need help with valve body removal (side ca
    There ya go, these 4 plus the lower right one.
  3. #3 Re: Installing Transgo SK4T65E shift kit - need help with valve body removal (side ca
    Jul 2012
    West Virginia
    If you are talking about pulling the valve body to replace the line and boost valves that come in the kit:
    You have to remove the wire harness first, then the pump bolts (all but the silver one...leave that one!). Remove the pump. Then remove the pressure switch. Then remove the bolts from the VB. Draw a picture of it because the bolts are different lengths and need to go back where they came from...same with the pump bolts. The valve body should now come off. Watch out for the check balls! You do realize that you are going to need new gaskets for the VB right?
  4. #4 Re: Installing Transgo SK4T65E shift kit - need help with valve body removal (side ca
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Any time the valve body is removed from a 2003+ 4T65E transmission you will also need to replace the valve body spacer plate with a new one from the dealer. Once you remove the valve body you lose the seal and the parts will leave impressions in the gaskets on the plate which will not properly seal if reused and can result in cross leaks and low pressure, definately not worth the risk reusing this item. The gaskets are glued on to the newer plates. You can grind them off but is not a fun chore to tackle and then you have a bare plate that you can use servicable gaskets with.
  5. #5 Re: Installing Transgo SK4T65E shift kit - need help with valve body removal (side ca
    Apr 2012
    Windsor, Ontario
    Thanks guys - looks like the car will be on the hoist for a few days. I will pick up a gasket & seal kit + order the spacer plate tomorrow.
    I found the torques after some more searching as well.
  1. transgo shift kit install Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2012, 11:19 AM
  2. Just Ordered Transmission Cooler and TRANSGO Shift Kit (UPDATED!)
    By lattyd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2012, 11:40 AM
  3. TransGo SK4t65E Question
    By threepttilt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-13-2011, 08:02 PM
  4. Evaporator case removal
    By vertebrate in forum General Tech Discussion
    Last Post: 08-12-2011, 09:57 PM
  5. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
