Thread: Disappearing Trans Fluid
Results 1 to 11 of 11
  1. #1 Disappearing Trans Fluid
    Jul 2012
    Homer Glen, IL
    Hello,
    I just recently started having my car ('05 GT/105K) shift a little rougher in lower gears, usually only first to second. I checked my fluid level and saw that it was a little low. Once I added fluid the problem went away. A day later and the problem returned, checked fluid, a little low, added fluid, problem went away, no spots on driveway. Same thing happened the next day. No evidence of a leak anywhere. I have had to put in about 2 quarts over the last week or so to keep it running smooth. Everywhere I park there are no stains and the trans is dry on all external areas.
    Anyone else experience this or know what may be causing it?
    Thanks for any help,
    Tom
  2. #2 Re: Disappearing Trans Fluid
    crawl under the car and look for wet spots.
  3. #3 Re: Disappearing Trans Fluid
    Jul 2012
    Homer Glen, IL
    No wet spots...completely dry.
  4. #4 Re: Disappearing Trans Fluid
    maybe your rad leaking trans fluid into the coolant but that's unlikely.
  5. #5 Re: Disappearing Trans Fluid
    check your radiator for the fluid to be in the coolant. the coolers break inside the rad.
    if this is the case, stop driving it, as if coolant gets back into the trans its over johnny.
  6. #6 Re: Disappearing Trans Fluid
    Apr 2009
    Fort Worth TX
    It may be only leaking when you're driving down the road. I would suspect cooling line seals at the transmission or input shaft seals.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Bingo, exactly what i am thinking.
    This post brought to you by.....
    For all your 3800 needs:
  8. #8 Re: Disappearing Trans Fluid
    Jul 2012
    Homer Glen, IL
    If this is this case, what would be the best course of action?
  9. #9 Re: Disappearing Trans Fluid
    Swap the radiator, change trans fluid and filter, flush coolant
  10. #10 Re: Disappearing Trans Fluid
    ^^^what he said.
  11. #11 Re: Disappearing Trans Fluid
    Jul 2012
    Homer Glen, IL
    ^^^what he said.
    Thanks for the help guys...much appreciated!!!
  1. Trans Fluid/filter
    By Pshnmeawy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-20-2011, 08:43 AM
  2. Tranny fluid disappearing?
    By jokyfo in forum General Tech Discussion
    Last Post: 10-27-2010, 09:07 AM
  3. There's trans fluid everywhere!!
    By FuglyGTP in forum General Tech Discussion
    Last Post: 09-05-2009, 05:08 PM
  4. Trans. Fluid?
    By BwolfGT in forum General Tech Discussion
    Last Post: 04-11-2009, 05:26 PM
  5. Recommended Trans Fluid
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-20-2008, 05:57 PM
