Thread: External Trans Cooler
Results 1 to 4 of 4
  1. #1 External Trans Cooler
    GT Level Member ls1camino's Avatar
    Laurel, MD
    I'm replacing my radiator this week. While I'm at it, I'm just going to upgrade to an external transmission cooler. Coincidence, Summit is running a special on B&M External Coolers, so I think I'll go with one of them. Should I just get the biggest one I can find? Is there such thing as "too big"? Should I be concerned with covering half of my radiator with my trans cooler?
    Here are the coolers I am looking at...
    8.5" x 11.25" x 1"
    B&M 70268 - B&M SuperCooler Oil Coolers - Overview - SummitRacing.com
    7.25" x 11.25 x 1.5"
    B&M 70264 - B&M SuperCooler Oil Coolers - Overview - SummitRacing.com
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: External Trans Cooler
    Either will probably fit. You'll have some fun taking the nose apart to put it in..but it's all good.
  3. #3 Re: External Trans Cooler
    GTP Level Member joshv's Avatar
    canada
    u wont need the biggest one u can get, i have one thats a little bigger then my hand, and i pulled it from a honda at the wreckers, it does the job for a gxp.
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  4. #4 Re: External Trans Cooler
    St. Louis
    Those supercoolers are nice. I run the 70268 on my 95 T-Bird and it worked great. IIRC, the supercoolers have a built in thermostat that will allow the fluid to bypass the cooler until it reaches a certain temp. so you don't have cold fluid staying too cold. Want to say it was around 160* when it opens up.
  1. Trans cooler
    By Ryan D. in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2011, 02:14 PM
  2. trans cooler and oil cooler
    By mhartwig in forum General Tech Discussion
    Last Post: 11-17-2010, 10:33 PM
  3. trans cooler?
    By boostedgtp2003 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-02-2010, 08:45 PM
  4. GM aux trans cooler
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 09:32 AM
