Thread: Loose Connector
Results 1 to 6 of 6
  1. #1 Loose Connector
    GT Level Member ShadowSwept's Avatar
    Kentucky
    I have a loose connector in my engine bay around the transmission.
    You'll have to forgive my terminology ignorance here, but the shift selector box on the top of the transmission has a wire going into it. About eight inches back from that connector another wire branches off to a connector that just dangles below the ABS box.
    I couldn't get a good picture of it, but if you follow that wire it's just off the bottom right corner:
    I've looked everywhere and I can't find anything to plug it in to. It's covered in gunk and looks like it may have never been connected. I looked in my SE for a reference and there was no wire branching off, and I can't find any wiring diagrams that show it.
    Any one know what this is for?
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  2. #2 Re: Loose Connector
    It's to your PS rack. Getting a pic
  3. #3 Re: Loose Connector
    Look down from the beige boot of the ps connection. See the wire that loops to the left of the pic. On this rack when it was bought remaned..it has your connector zip tied to the lines. Usually it's just laying there by the bottom of the column (beige boot area)
  4. #4 Re: Loose Connector
    Kentucky
    I'm not seeing any boot, or anything beige for that matter, I must be blind. I did find a huge ball of tin foil that wasn't there before
    What does this do? If it's PS related shouldn't I have noticed a problem?
    2003 Grand Prix GT
  5. #5 Re: Loose Connector
    Nah.might be for the magnasteer. Sooo instead of looking for beige. See where the steering column would come out and go into the rack? Now look about 3 inches lower and that's where the connector should be. Some racks didn't have it. If your rack was replaced with the wrong one..it may not have it.
    The blob of tinfoil was your firewall/tunnel heat shielding.
    Firewall w/o insulation
    Inslulation on firewall. See near the tunnel for the exhaust how it's got foil. Likely that's yoru blob of it.
  6. #6 Re: Loose Connector
    Kentucky
    Okay, I see what you're talking about now (I was blind), but theres no connector or wire, and the connector I'm talking about wouldnt reach that far. It's just a short wire about three inches at most that sticks out directly betweet the ABS and the driver side axle.
    As for the foil; the firewall's intact. The ball of foil sat between the crossover pipe and the transmission, and I know for a fact it wasn't there a couple days ago. I pulled it out and unwrapped it and it had crumbs in it. There was also an oddly shaped razor blade under it- kind of curved with a flat edge.
    is with my car?
    2003 Grand Prix GT
  1. 04+ Loose fog light??
    By gpse2000 in forum General Grand Prix Discussion
    Last Post: 03-26-2012, 08:46 PM
  2. HELP ! can not get my bolt loose HELP !
    By pughman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2011, 08:11 PM
  3. Hubs are loose
    By Clar2478 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2010, 04:03 PM
  4. Loose Fuse?
    By dagger in forum General Tech Discussion
    Last Post: 05-02-2009, 06:08 PM
  5. something seems loose
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 03-08-2008, 01:55 PM
