Well I wouldn't exactly call them scientists...too many variables they didn't account for and they only sampled 2 vehicles, and only one was an automatic. I coulda told you from the start that the manual wasn't going in R.
Any updates?
Sounds like the same problem we had with the gfs car, at a stop light start going and in would slam into gear, we pulled the pan, and we found clutch material, brass, and metal shavings in the filter. ended up replace the whole trans with a new one. We had the same problem and the dealer could never figure it out, also have the dealer check ur line pressure.....it should be in the lower teens. Good luck!!
You could just let bill drive it he's pretty good at ripping transmissions out lol
This thread does not deliver. I am disappointed.
