Thread: How much slip is ok?
Results 1 to 3 of 3
  1. #1 How much slip is ok?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    I know that the tranny should slip just a tad and be ok, not feeling or noticing anything. But how much is ok, for the TC.
    Just curious because I was not able to find my answer else where without spending hours of research.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: How much slip is ok?
    I assume you are driving and you are talking about TCC slip when it's engaged? if it's fully engaged, say under 20-50rpm.
  3. #3 Re: How much slip is ok?
    Alaska
    Yes exactly what you mentioned. Thanks for the info.
    I guess my car seems to go up to 90 RPM.
  1. Clutch slip?
    By bobeebob in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2012, 06:19 PM
  2. Belt slip
    By TTalon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2011, 02:30 AM
  3. tcs and trans slip???
    By Justin48 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2010, 09:06 AM
  4. Belt Slip
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2010, 09:21 PM
  5. 1st gear slip BAD
    By Jesse1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-04-2010, 06:34 PM
