Thread: Tranny cooler or no cooler?
Results 1 to 11 of 11
  1. #1 Tranny cooler or no cooler?
    SE Level Member kc199's Avatar
    Nov 2011
    KCMO
    Hopefully going to be switching out the 4T65E tranny in my GT for a lower mileage one soon. I was thinking about the flushing of the tranny cooler and whether a tranny cooler was even necessary. I know the theory behind the cooler is to keep the fluid cooler and cleaner, thereby keeping it going longer. But is heat really a problem with the GP? Doesn't the pcm monitor the tranny temp and throw codes when the fluid temps are getting to high?
    Anyone gotten rid of the tranny cooler and if so how did you plug the tranny lines going into the tranny?
    1999 GT
  2. #2 Re: Tranny cooler or no cooler?
    the tranny cooler really does help out. the only issue with it is that it introduces more places for leaks to occur. i would definitely keep it. however, an external one to the stock radiator would be preferred.
  3. #3 Re: Tranny cooler or no cooler?
    dont by pass the stock trans cooler, if anything add a larger cooler to the set up, cooler trans temps mean a longer life. heat is a killer.
    if you were to by pass the cooler altogether, you would have to loop the trans lines of the radiator. not a good idea though.
    Id be afraid of the stock cooler failing.
  5. #5 Re: Tranny cooler or no cooler?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    I plan on running an aftermarket cooler. If you still use the stock one either in series with an aftermarket then you are having the additional heat from the coolant from the engine to deal with. By running a totally remote cooler you can get the trans temps where you want them to be.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  6. #6 Re: Tranny cooler or no cooler?
    Which no one ever does.
  7. #7 Re: Tranny cooler or no cooler?
    Nov 2011
    KCMO
    Looks like I will be going with an aftermarket unit. Any suggestions of good ones? Looking at Jegs and Summit right now, but RockAuto isn't too bad on price.
    1999 GT
  8. #8 Re: Tranny cooler or no cooler?
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    alot of people over on gmls4.net does. the best way to do it is to pull the factory radiator/trans cooler and have it hot flushed several times. then run the the aftermarket cooler in conjunction with the factory.
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  9. #9 Re: Tranny cooler or no cooler?
    I was referring to not placing it in front of the rad.
    Bunnell, FL
    There is some info in my sig on the gm trans coolers
    Android Fire
    I'm a Sex Offender
  11. #11 Re: Tranny cooler or no cooler?
    ahh. my mistake
    2006 Grand Prix GXP
    http://gmls4.com
  1. tranny cooler psi?
    By tonglebeak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-09-2012, 07:52 AM
  2. trans cooler and oil cooler
    By mhartwig in forum General Tech Discussion
    Last Post: 11-17-2010, 10:33 PM
  3. Tranny lines for trans cooler
    By monsterjam5000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2010, 04:09 PM
  4. Replies: 9
    Last Post: 02-13-2009, 05:22 AM
  5. Thinking about a Tranny Cooler, what do you guys have...
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-30-2008, 09:37 PM
