Thread: lost "D" and "3" the car only move forward in 2nd
Results 1 to 3 of 3
  1. #1 lost "D" and "3" the car only move forward in 2nd
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    99 gtp 171k miles and i lost D and 3 on the shifter it only moves forward in 2, im thinking i blew the trans because theres no solenoid from 2nd to 3rd in these transmissions. id like your guys thoughts though
  2. #2 Re: lost "D" and "3" the car only move forward in 2nd
    Forward band most likely.
    Will need to be rebuilt.
  3. #3 Re: lost "D" and "3" the car only move forward in 2nd
    Foward band for sure.
    You can confirm this by dropping the pan and feeling up the band. If it's wiggly jiggly or pieces are in the pan. Typicallky though...that's the issue you are experiencing
  1. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  2. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
