Thread: 4t65e-HD Part Identification (Pin/Dowel with spring)
Results 1 to 4 of 4
  1. #1 4t65e-HD Part Identification (Pin/Dowel with spring)
    Mar 2012
    United States
    I am in the process of changing out my solenoids in my Grand Prix, however just when I was about to button it up I find this part lying on the ground. Any idea what it is and where to put it back. The pin is right at 1 inch long and about 3/8th wide with groves on both sides. and it has a *Very* small spring that goes inside the case. TIA
  2. #2 Re: 4t65e-HD Part Identification (Pin/Dowel with spring)
    Tough to say, take a look at the various parts etc in this fix pdf. I would think that has to be a valve body piece.
    http://www.sonnax.com/system/instruc...C-4T65E-IN.pdf
  3. #3 Re: 4t65e-HD Part Identification (Pin/Dowel with spring)
    Mar 2012
    United States
    Thanks, best I can make out is it being the servo boost valve. I dont want to put this thing back together without putting it back in.
  4. #4 Re: 4t65e-HD Part Identification (Pin/Dowel with spring)
    Take a look at some of the various info in the "trans info" post by me. I think it shows how to check all those valves and the clips that hold them.
  1. 4T60 part identification help...
    By Severoux in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 02-07-2012, 07:57 AM
  2. Identification tag?
    By Six2stackmonster in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-25-2011, 04:44 PM
  3. Vacuum Part Identification (pics)
    By SlowNA06 in forum General Tech Discussion
    Last Post: 07-22-2010, 11:18 PM
  4. fuel line identification help
    By sra_chipmunk in forum Off Topic Discussion
    Last Post: 07-06-2008, 12:30 PM
  5. Cam sensor dowel?
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 04-20-2008, 07:54 PM
