Thread: Another GXP clunking thru the gears???
Results 1 to 4 of 4
  1. #1 Another GXP clunking thru the gears???
    Mar 2012
    United States
    It's a 07 GXP. From what I've read it seems I'm not alone. Snaps your neck sometimes because the tranny can't figure out what gear its in and when it does figure it out you get the clunk. Also today at about 1/4 throttle it went from 1st to 3rd in a terrible fashion. My question is I've contacted the extended warranty company and they keep saying no codes no fix. Not to mention its a 200 mile round trip to take it to the dealer holding the warranty. I've had it looked at locally but it won't throw a code and until it does they don't want to see it. Should I keep harassing them or let it grenade that'll surely throw a code. Or is this just a common issue and I'll last long enough to be some else's problem in a few years?
  2. #2 Re: Another GXP clunking thru the gears???
    GT Level Member GMCustomerService's Avatar
    Michigan
    moneypits,
    How often does this occur? Is this a recent issue? Does it only happen during cold operation? You stated you had the vehicle looked at locally, were they able to replicate the problem?
    I look forward to your reply.
    Louis
    GM Customer Service
  3. #3 Re: Another GXP clunking thru the gears???
    Mar 2012
    United States
    They could not replicate the issue. It just does it at random hot or cold.
  4. #4 Re: Another GXP clunking thru the gears???
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    gxp's are problems right rom the factory because of the trans. gm did a horrible job swapping this motor in. get the trans built from TEP.
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  1. clunking noise
    By jessejj79 in forum General Tech Discussion
    Last Post: 02-28-2011, 12:49 PM
  2. Clunking....anyone???
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 08-23-2010, 03:18 PM
  3. clunking noise?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-07-2009, 02:55 AM
  4. clunking
    Last Post: 07-20-2009, 06:25 PM
  5. clunking
    By QwikGT in forum Brakes/Suspension/Chassis
    Last Post: 03-06-2009, 08:30 PM
