Thread: Tranny Swap 4T65E-HD to 4t65E
Results 1 to 5 of 5
  1. #1 Tranny Swap 4T65E-HD to 4t65E
    Need a quick fix for my daily driver and I'm thinking of just doing a quick tranny swap. I can find relatively inexpensive non-HD trannys around for my 2000 GTP. I know the difference is in the differential and that CV shafts are different lengths and gear ratio is different. Am I able to switch the HD stuff and gear/chain drive to the non-HD tranny so I don't have to buy new shafts and tune out the gear change?
    Ohio
    Yeah that's no problem.. Just be easy on it
  3. #3 Re: Tranny Swap 4T65E-HD to 4t65E
    Portland Oregon
    Yea you shouldn't have a problem swapping that stuff out. Swap the HD Diff and cover, and the chain set. You'll need valve body gaskets and channel plate gaskets but other than that you'd be fine.
    Quote Originally Posted by 99pgpgt View Post
    I have a "non-hd" that's been converted to an HD in my GTP now and I'm close to running 12's on it. You don't have to be easy on nothin.
  4. #4 Re: Tranny Swap 4T65E-HD to 4t65E
    Ohio
    does it have the factory hardened parts in it?
  5. #5 Re: Tranny Swap 4T65E-HD to 4t65E
    Perfect thats what I thought and wanted to hear.
  1. 4t65e to 4t65e-hd swap
    By kc199 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-22-2011, 04:11 PM
  2. 2000 4T65E HD tranny in a 1998 GTP with no problem in swap......but!!
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2009, 10:53 AM
  3. 4T65E HD tranny swap and perf. shift question
    Last Post: 06-27-2009, 11:49 AM
