Thread: 04 grand prix gtp cooler lines
Results 1 to 5 of 5
  1. #1 04 grand prix gtp cooler lines
    SE Level Member TheManInBlack's Avatar
    Dec 2011
    Detroit, Michcigan
    has anybody ever changed the trans cooler lines on a 04 grand prix? And what"s the best way to pull the line going to the radiator just beneath the lower radiator hose? Any advice would be appreciated. -Joe
  2. #2 Re: 04 grand prix gtp cooler lines
    Both lines should be above the lower radiator hose where they enter the radiator. They are clip or click style fittings. So you buy a set of clips from teh dealer ahead of time. Then pull back on the piece of plastic covering the fitting and use a pick to send your clips across the room into the vast unfindable corner. Or be super careful with yours and skip buying a set. Then the lines are typicall held with a screw or plastic retainer to the lower radiator support and they click into the trans as well.
    don't forget the 13mm holding the lines to the trans.
  3. #3 Re: 04 grand prix gtp cooler lines
    Dec 2011
    Detroit, Michcigan
    Haha yea those those clips really go flying.
    The lower one i got the clip out and the plastic piece off but the line wouldn't come out at all. So i may just leave that one on. I even tried takeing the threaded fitting straight out of the radiator but since its so hard to even get to with it being under the radiator hose and next to a bunch of crap i can't even do it that way.
    But i can get those clips from the dealership though?! I've definately lost a few clips this bout..
  4. #4 Re: 04 grand prix gtp cooler lines
    Yup...and their technical name is Effing transmission line holding clip. Parts guy will know exactly what you need.
    I sometimes spray a little penetrating oil at them and then wiggle the lines loose.
  5. #5 Re: 04 grand prix gtp cooler lines
    Dec 2011
    Detroit, Michcigan
    Haha. I tried pb's penetrating oil, tried wiggleing it every which way possible.. Its still on there. It's not completely rusted or anything
  1. Transmission cooler lines
    By jakeb157 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-01-2011, 12:09 PM
  2. Transmission Cooler Lines
    By tdm571 in forum The Rant Forum
    Last Post: 02-27-2011, 07:17 PM
  3. Tranny lines for trans cooler
    By monsterjam5000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2010, 04:09 PM
  4. Transmission Cooler Lines
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-01-2010, 08:53 AM
  5. Trans cooler lines, which is IN and which is OUT?
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2008, 11:45 AM
