Thread: 4T60e shreds planetary gears
Results 1 to 5 of 5
  1. #1 4T60e shreds planetary gears
    May 2011
    Bremen,GA
    Rebuilt 4t60e in 97 gp gt about 1600 miles ago,differential looked good and was tight with fresh spider gears.
    The loud roaring sound that resembled a really bad wheel bearing turned out to be shredded planetary gears
    on the differential,my foot is heavy,but I would appreciate any other suggestions as to what else could have
    caused this kind of damage. I'm hoping that the shrapnel went straight into the pan and was stopped by the
    filter,didn't see any in the diff. cover.
    I was planning on dropping the pan and using carb cleaner to flush the diff. area,then replace fluid and filter.
    Do you guys think that would be sufficient,or should I tear the whole thing down and start over?
  2. #2 Re: 4T60e shreds planetary gears
    Portland Oregon
    Pull the diff and inspect the final drive ring gear. Had one that was missing a few teeth and kept chewing up planetaries. Also, check all the Torrington bearings and such while you're in there.
  3. #3 Re: 4T60e shreds planetary gears
    May 2011
    Bremen,GA
    Will do,thanks OH4.
  4. #4 Re: 4T60e shreds planetary gears
    Portland Oregon
    No prob. For your sake I hope it's not the ring gear. It's the last thing that comes out of the trans during a rebuild. Has to go out the other way
  5. #5 Re: 4T60e shreds planetary gears
    May 2011
    Bremen,GA
    I should tear it all down anyway,to remove the metal.
    The possibility of being able to heard all of the shrapnel into the pan with some cleaner seems pretty slim to me.
  1. 4T60E-Loud popping sounds,then no gears
    By 97gpl36 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 01-18-2012, 05:04 AM
  2. Need help with 4T60E
    By southgamisfit in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 02-01-2011, 09:17 AM
  3. Creed Shreds!!!
    By Reptile in forum Off Topic Discussion
    Last Post: 10-16-2008, 01:13 PM
  4. need help with 4t60e
    By ez35 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 09-05-2008, 03:28 PM
  5. Help with 4T60E
    By rockthunder in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-23-2008, 01:11 AM
