Thread: Pulled CV on drivers side, Tranny shaft came with!
Results 1 to 11 of 11
  1. #1 Pulled CV on drivers side, Tranny shaft came with!
    owasso, ok
    Hey guys, got a question on changing out CV axel, drivers side.
    I had to replace it back in March this year and then bought a big crowbar to seperate it from the transmission.
    I noticed a constant whinning (just like the brake indicator) just after doing that work, but ignored it until I had the patience to mess with it again. I finally got a round to pulling the wheel off to find that the boot next to the wheel was sliced.
    I got a replacement, but then when I tried (for seemingly hours) to pull the CV out again, the entire shaft inside the transmission came out with it. After pulling about a foot, thinking 'this isn't right', I freaked out for about 20 minutes and prayed to the Gods I didn't screw it up completely.
    I set the whole thing back in hoping it would still run.
    It's fine, but the CV joint still need changing. Any ideas?
    And any one know where that wheel noise be coming from? Changed the rotors and the pads back in March and they're wearing fine.
    Thanks for any help. Starting to look at giving in and freeing up my weekends.
  2. #2 Re: Pulled CV on drivers side, Tranny shaft came with!
    Brewcity, WI
    So your saying your worried about taking half of this out... black part in upper left of photo?
    I would just replace the whole c v shaft as pictured above. At least thats what I did when I did mine, didn't wanna deal with boot replacement, etc.
    search works here....
    Self-denied SMGPFC member #1
    SEARCH works!
  3. #3 Re: Pulled CV on drivers side, Tranny shaft came with!
    Portland Oregon
    Pepino, he's saying the output shaft came out with the CV Axle. It happens. Best bet to get just the CV axle out is getting two pry bars or long screw drivers in there and put alternating pressure on it so it's like a wiggle. It helps it overcome the spring clip on that side.
  4. #4 Re: Pulled CV on drivers side, Tranny shaft came with!
    Brewcity, WI
    Quote Originally Posted by OH4CompG View Post
    I had better luck with quick jolts and not gradually increasing pressure, while dealing with the spring-clip PITA.
    I just re-read it and, reading comprehension > Me (today)
    SEARCH works!
  5. #5 Re: Pulled CV on drivers side, Tranny shaft came with!
    Waukesha, WI
    i used a axle popper
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  6. #6 Re: Pulled CV on drivers side, Tranny shaft came with!
    owasso, ok
    Thanks fellers. I'll go at it again this coming weekend and try applying pressure to the other side of it, for the wiggle affect.
    I was worried about pulling the tranny shaft out to a point of no return? without having to take it to the shop.
  7. #7 Re: Pulled CV on drivers side, Tranny shaft came with!
    owasso, ok
    Nah. I know what that looks like. Add a foot.5 to it, and that's what I was curious about.
  8. #8 Re: Pulled CV on drivers side, Tranny shaft came with!
    Yes..pushing inward towards the trans and giving it a quick jolt is how you'll end up getting those seperated.
    Although..if you gently take the shaft all the way out as well. You can hold the output shaft (part from inside trans) and hit the back of the inner cv joint with the hammer to get it off the output shaft. Then put grease on the clip of the output shaft that will go into the trans first to center it. Then gently slide it in and when you get to the last inch or so..it'll need a tap with a mallet to seat it into the differential.
  9. #9 Re: Pulled CV on drivers side, Tranny shaft came with!
    owasso, ok
    That was my concern. Pulling it out through gears that may potentially be held in place by the output shaft, and not being able to get it back in effectively. Stranger things have happened, with my luck.
    Have any of you had a hub go out that squeals like worn brakes?
  10. #10 Re: Pulled CV on drivers side, Tranny shaft came with!
    The nice thing about our transmissions is that output shaft is put in last. Literally it's the last step.
    Only thing to keep in mind is putting the grease on the circlip that will travel through the trans, because 2/3's of the way through there's a plastic lube dam that can be broken if forced. So you grease that clip to keep it centered on the shaft and gently insert the shaft. Otherwise..it's not a problem/worry.
    Not usually on the hub..but it's a bearing.
  11. #11 Re: Pulled CV on drivers side, Tranny shaft came with!
    owasso, ok
    I appreciate it Bill. This post is always very helpful because of the pool of knowledge it gathers.
  1. AC blows Ice Cold on the Passengers Side and warm on the Drivers Side.
    By rynoman03 in forum General Tech Discussion
    Last Post: 08-08-2011, 11:18 PM
  2. Can't Get Drivers CV Shaft Out
    By grandamle91 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-18-2011, 03:34 PM
  3. A/C cold on passenger side and luke warm on drivers side
    By IFrees in forum General Tech Discussion
    Last Post: 05-14-2011, 05:06 PM
  4. drivers side CV shaft
    By Jakegday in forum General Tech Discussion
    Last Post: 07-03-2010, 05:42 PM
  5. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
