Thread: GTP stalls when shifted into reverse
Results 1 to 2 of 2
  1. #1 GTP stalls when shifted into reverse
    SE Level Member ejechtion54's Avatar
    Ft. Wainwright
    The past couple of days I have noticed when I put my car into reverse the idle bogs down and can stall unless I press the accelerator. It's fine in all other gears, reverse is the only one. A mechanic I know tighten up the idle cable on the throttle and that resolved some of the issue but it still bogs down. Any idea on what is going on? There is no grinding of gears when I shift and fluid levels are good.
    Who ever said "Out with the old and in with the new."?
  2. #2 Re: GTP stalls when shifted into reverse
    Ft. Wainwright
    I also noticed that there is a heavy smell of fuel when shifting into reverse and driving off, I think that's the computer compensating for the low idle to raise the RPMs though.
  1. Transmission Can Only Be Shifted Manually
    By devinpitcher in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-09-2011, 12:31 AM
  2. Trunk Release activated when shifted into Park!
    By midknight75 in forum General Tech Discussion
    Last Post: 01-06-2011, 08:27 AM
  3. shaking only when shifted into second gear
    By gtpinsc in forum Brakes/Suspension/Chassis
    Last Post: 12-19-2010, 09:40 PM
  4. 98 gtp stalls
    By swwalker09 in forum Introductions/Noob Questions
    Last Post: 10-07-2010, 05:22 PM
  5. Tranny knocks when shifted to gear
    By Viper in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 01-27-2009, 04:11 PM
