Thread: 4t65e side cover gasket $29.99 Advance auto
Results 1 to 10 of 10
  1. #1 4t65e side cover gasket $29.99 Advance auto
    May 2011
    illinois
    for anyone who is going to open up their 4t65e for any reason and the side cover gasket needs to be replaced. advance auto has Felpro side cover gaskets for $29.99. use a discount code and get even more $ off.
  2. #2 Re: 4t65e side cover gasket $29.99 Advance auto
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I would be curious about this one, you better inspect this to make 100% sure it is a molded metal/rubber OE style replacement. It could be a misprint and is a black cork/rubber style side cover gasket for a 4T60E. Would be great to see something come out cheaper but none of my parts suppliers have had anything other than the original type and they are not cheap.
  3. #3 Re: 4t65e side cover gasket $29.99 Advance auto
    May 2011
    illinois
    it is metal and rubber. there is a picture on the website
  4. #4 Re: 4t65e side cover gasket $29.99 Advance auto
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    It's probably a low quality rubber that degrades is a couple of years causing a leak.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  5. #5 Re: 4t65e side cover gasket $29.99 Advance auto
    That would be great. Heck, I'd replace them as part of any work with teh side cover if they are that cheap.
    Advance has some funky stuff between their online pricing and in store pricing. I'm a commercial acct there and yet, can buy cheaper online. Add in the discounts like Dave mentioned and you can save piles.
    Anyone want another good one. Get a lower conversion gasket set (fel pro) when in need of an oil pan gasket. It's cheaper to buy the whole kit than just a pan gasket.
  6. #6 Re: 4t65e side cover gasket $29.99 Advance auto
    May 2011
    illinois
    I've never had any issues with felpro. they are quality gaskets
  7. #7 Re: 4t65e side cover gasket $29.99 Advance auto
    Quincy, Mass
    the felpro side cover gasket is only $23.79 at rockauto.com, it appears to be metal and rubber by the picture
    No more GP 04 Impala SS Indy:
  8. #8 Re: 4t65e side cover gasket $29.99 Advance auto
    Fort Wayne, IN
    I will have to look into it a bit more and try to order one. The 4T60E also used a molded metal/rubber side cover gasket and those are cheaper in general so hopefully it is not an incorrect application problem. It would definately be great to see these a lot cheaper than what is available from trans parts suppliers and dealers.
  9. #9 Re: 4t65e side cover gasket $29.99 Advance auto
    May 2011
    illinois
    there is no shipping with advance auto. you just go to the store and pick it up once you do the transaction online. plus you can use their discount code and get it for the same price as rock auto. I googled advance auto promotion discounts and used the one that obviously is the best discount .
  10. #10 Re: 4t65e side cover gasket $29.99 Advance auto
    Nov 2008
    upstate ny
    whats the part number from advance
    , i cant find it in my searches
  1. oem or advance auto?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 06-23-2011, 11:42 AM
  2. Advance Auto Parts Discount
    By Lawngoose in forum Off Topic Discussion
    Last Post: 07-16-2010, 02:31 PM
  3. advance auto sale (today only)
    By noreasonwhyy in forum Off Topic Discussion
    Last Post: 05-16-2010, 10:08 PM
  4. Replies: 15
    Last Post: 03-17-2010, 05:06 PM
  5. Front Strut Mount from Advance Auto Parts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 04-02-2009, 11:53 AM
