Thread: cat. can cause shift problems.
Results 1 to 2 of 2
  1. #1 cat. can cause shift problems.
    Apr 2011
    Wayland,Iowa
    Hello to all,I am posting this to maybe help others. I have a 01 GTP and have searched and searched for help with the shifting problems. Mine would not shift properly on its own and if I shift it manually,it would run better. I had the codes run on the trans. and the exhaust.The trans, was fine,the catyletic converter showed 70 percent collapsed. This pushs burt emmisions back into the engine causing it to spudder. The PCM then comensates for odd shifting in the trans. Replace,remove or have the cat. checked. I hope this helps with your ride,it did mine. Thank you.
  2. #2 Re: cat. can cause shift problems.
    Pennsylvania
    ehh I dont let my cat touch my car anymore... last time I let him swap out my valve springs and he got hairballs in the cylinder and his claws effed up my paint. If he messed up the tranny that would be the end of him...
    jk I've been havin some minor shifting oddities lately with no codes, I'll chime in when I get my new downpipe and cat in the next month or so and see if it improved conditions.
  1. performance shift problems and bulb question
    By 99prixgt in forum General Tech Discussion
    Last Post: 09-13-2010, 10:08 PM
  2. 911...Need help, Shift kit problems
    By cadman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-13-2009, 07:10 PM
  3. Shift Interlock Problem & Coolant Gauge Problems
    By 98GTPON22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2009, 04:02 PM
  4. Shift Problems
    By madden_02 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-04-2009, 09:42 PM
