Thread: Transmission Slipping on 97GTP. Interchange?
Results 1 to 7 of 7
  1. #1 Transmission Slipping on 97GTP. Interchange?
    May 2011
    Michigan
    I have a 97 GTP with over 200k on it, The transmission is starting to slip on it, I want to get a used transmission and put it in, My question is what do I need to look for for a 4t65e-hd? does it have to be from a grand prix or will that trans out of another model work? I found a couple for sale but they show having the 3.29 ratio, whats the ratio on the GTPs?
    From my understanding is the 1997 SE and GT models still used the 4t60e vacuum controlled trans and the 97 GTP models had the 4t65E along with all 98-03 3800. am I correct?
    Basically I want to know what my options are for a used tranny.
  2. #2 Re: Transmission Slipping on 97GTP. Interchange?
    Only the GT in 97 has the 4t60e, everything else has either the 4t65e or the 4t65e-hd, from what I have read you can use a 4t65e and just put the differential driveshaft and there was something else but I cant remember what it is off the top of my head, and it will work.
  3. #3 Re: Transmission Slipping on 97GTP. Interchange?
    find a 97-02 HD trans and swap it out
    The GTP trans is 2.93 gearing and the GT's are 3.29
  4. #4 Re: Transmission Slipping on 97GTP. Interchange?
    May 2011
    Michigan
    Ok, I found a locak guy that has a trans out of a GT with a ZZP shift hit and a HD conversion kit in it with 50 on it, what will I need to do to make it work having the 3.29s?
  5. #5 Re: Transmission Slipping on 97GTP. Interchange?
    changing the PCM tranny files aka custom tune.
  6. #6 Re: Transmission Slipping on 97GTP. Interchange?
    May 2011
    Michigan
    so im assuming that would involve sending the pcm to zzp, basically add 125 to the bill
  7. #7 Re: Transmission Slipping on 97GTP. Interchange?
    no, ZZP will kill your car if anything.
    Just gotta have a guy with hp tuners do it.
    But for real man, why on earth do you want to create more headache for yourself. Just buy a GTP tranny and do a direct swap.
  1. Transmission is slipping in drive
    By KarenC in forum General Tech Discussion
    Last Post: 06-01-2011, 03:22 PM
  2. transmission slipping or something else?
    By thegipper in forum Off Topic Discussion
    Last Post: 12-28-2010, 04:41 PM
  3. transmission interchange?
    By kaptainkx in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-02-2009, 12:03 PM
  4. Transmission slipping?
    By WGPGT00 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2008, 07:27 AM
  5. transmission slipping occaisionaly
    By twistin*6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2008, 08:35 PM
