Thread: TCC lock up solenoid bad. 98 gp gt
Results 21 to 40 of 69
  1. #21 Re: 3.8, power loss, rpm flux, please help
    These motors dont idle very smoothly so an exhaust leak wouldnt help.
  2. #22 Re: 3.8, power loss, rpm flux, please help
    Banned
    Apr 2011
    wv
    it was running pretty good tonight. it was raining. i know that rain affects your air/fuel ratio in a carbeurated vehicle. maybe its still running lean? where are all possible points for a vacuum leak? and whats the best way to check?
  3. #23 Re: 3.8, power loss, rpm flux, please help
    All of the vacuum lines and the LIM gasket where the LIM meets the block and heads.
    When the "plenum" meets the LIM. and TB.
    Spray carb cleaner, listen for idle change.
  4. #24 Re: 3.8, power loss, rpm flux, please help
    Banned
    Apr 2011
    wv
    i already replaced the lim, the plenum gasket, and throttle body gasket. its got a brand new fpr line as well. could it be the lock up torque converter? seems like it could be locking and unlocking. although it does it in both third and forth.
  5. #25 Re: 3.8, power loss, rpm flux, please help
    Banned
    Apr 2011
    wv
    matt your avatar is hilarious
  6. #26 Re: 3.8, power loss, rpm flux, please help
    it could be the converter.
    but when replacing the LIM gaskets you normally end up breaking the vacuum lines.
    They need replacing because they've dry rotted due to age.
  7. #27 Re: 3.8, power loss, rpm flux, please help
    Pennsylvania
    For the love of god, please please please please check the rubber "T" on the vacuum line right off your lower intake manifold. This is a vacuum leak. In fact, pull the thing off an inspect it for a tear, even if it looks good.
  8. #28 Re: 3.8, power loss, rpm flux, please help
    Florida
    what are your mods?
  9. #29 Re: 3.8, power loss, rpm flux, please help
    Banned
    Apr 2011
    wv
    er rockers, hv3, 1.0pcm, res and ubend delete. soon to top swap
  10. #30 Re: 3.8, power loss, rpm flux, please help
    Banned
    Apr 2011
    wv
    what T are you talking about. im talking about the 3.8 theres no T on it
  11. #31 Re: 3.8, power loss, rpm flux, please help
    He's thinking about a s/c'd car.
    you just have the two lines off the front of the TB and all of the rest is simply gasket issues if they exist.
    What is your IAC at when the car is warmed up and idling?
  12. #32 Re: 3.8, power loss, rpm flux, please help
    Banned
    Apr 2011
    wv
    Idle air control? idk i just replaced it last summer. did it before that, still doing it
  13. #33 Re: 3.8, power loss, rpm flux, please help
    GT Level Member clevelandfan's Avatar
    ohio
    i would spray starter fluid all around the throttle gaskets, and all around the intake gaskets. u could be leaking. if the rpms raise a little then u prob do. quick easy backyard test.
    97' Grand Prix. Blurring the lines between SE, and GT
  14. #34 Re: 3.8, power loss, rpm flux, please help
    Kansas
    For the fluctuation, my guess is the torque converter. If you have a scan tool, drive down the road and if you can, manually lock in the torque converter while going down hill. If your RPM jumps stop, than that's probably your issue. And you can check your TCC slippage and duty cycle.
  15. #35 Re: 3.8, power loss, rpm flux, please help
    Banned
    Apr 2011
    wv
    ok explain to me how to do all of that. ive been thinking it was the converter for almost a year but couldnt get anybody to confirm it. ive got an SES scan tool, but thats it.
  16. #36 Re: 3.8, power loss, rpm flux, please help
    Banned
    Apr 2011
    wv
    how do you lock it manually?
  17. #37 Re: 3.8, power loss, rpm flux, please help
    SE Level Member T0pwater's Avatar
    SW Michigan
    You need a good scanner with capability of 2-way communication. I don't know exactly which ones will work, but I know it's gonna be expensive. I've got my eye on the autoenginuity laptop-based scanner. You'd need the base scan package plus the GM pack. ~400 total if you get the base scanner on ebay.
    I agree I think TCC is most likely. Also, I like propane for vacuum leaks. Less messy, less risk of fire.
  18. #38 Re: 3.8, power loss, rpm flux, please help
    Banned
    Apr 2011
    wv
    the motor is tight. theres no leaks. all new gaskets, new LIM gasket, new plenum, new MAF, TPS, MAP, IACV, PCV valve, etc. new fuel pump, new injectors, new plugs, wires, all new coil pack. in fact the only things i havent touched are the ICM, CPS, and O2 sensor. no codes, no check engine light. idk what to do.
    the exhaust manifold gaskets are leaking. picked up a set. im gonna swap them out when i get a chance but havent gotten round to it.
  19. #39 Re: 3.8, power loss, rpm flux, please help
    Banned
    Apr 2011
    wv
    what would cause the torque converter to do that? is it a bad converter, or a bad signal?
  20. #40 Re: 3.8, power loss, rpm flux, please help
    Kansas
    I use a Snap On Solus scan tool that allows two way communication as T0pwater said. I'm guessing component wear would be the reason. I had a remaned w/ 5k on it and I had that issue happen. Tried clearing tranny adapt settings and so on, nothing worked, but we did get it to lock in via the scan tool. Needless to say, my tranny was replaced under warranty.
  1. power loss
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 01:16 AM
  2. another loss of power :S
    By ChdMcD in forum General Tech Discussion
    Last Post: 07-31-2010, 07:08 PM
  3. power loss
    Last Post: 04-15-2010, 02:57 PM
  4. power loss when hot
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 03:23 PM
  5. power loss
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 11:12 PM
