i have a 2000 gtp coupe with 133000 (odometer acting weird but thats another issue). when the engine is cold it drives normal, after heating up, when coming to a stop at a light or something as its shifting down through its 3-2-1 gears its like it slips and jerks as if its hitting the gas for half a second before it catches the next gear down. finaly when it gets into first gear and i come to a stop and idles, the rpm's will fluctuate between 200 and 1500 rpms for a second before leveling out to a ~700 rpm smooth idle. it upshifts just fine and has no issues as far as hard shifting even when flooring it. just want some insight as to what the problem is. thanks!
