how did u manage this one?
What I'm seeing is a broken TC to flex bolt. You should have three bolts or three holes in the TC for bolts to go through the flex into the TC to hold them together.
I see something behind that flex hole..and it's not a TC hole for the bolt. I'm thinking the part you think is a hairline fracture is the outline of the broken bolt in the threaded hole.
My guess is the T/c Ballooned
Can you describe the noise?
Flex looks intact. The way we are looking at it, I thought that was one of the TC bolt holes.
I'm thinking you have an issue there. Typically TC's only touch the flex where they are bolted. That's the only places i've seen bosses/pieces welded on that touch.
