Thread: 2000 Grand prix Tranny problem
Results 1 to 8 of 8
  1. #1 2000 Grand prix Tranny problem
    Welland , Ontario
    I have a 2000 Grand Prix Gt and the problem i have is the tranny cooler line went at a intersection i got towed home and fixed the leak filled the tranny with the proper fluid started it up and now a new problem has came up the car will move in reverse under it own power but will not move forward in any forward gear now i do have limited money and want to fix it my self if possible any info on what it could be or what to check and how to would be greatly appreciated
  2. #2 Re: 2000 Grand prix Tranny problem
    It does nothing if you pull it down to 2 or 1 on the shifter?
    I'm inclined to say forward band ...but you'd have movement in 2 and 1 of the shifter.
  3. #3 Re: 2000 Grand prix Tranny problem
    Welland , Ontario
    No it does nothing in any forward gear
  4. #4 Re: 2000 Grand prix Tranny problem
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    From TEP's website for no gears, But since you have reverse IDK
    -Broken input shaft
    -Broken drive chain or sprockets
    -Extremely low fluid level
    -Broken ouput shaft
    -Clogged filter from excessive debris in fluid
    -Broken oil pump shaft
    -Stripped torque converter splines
    -Broken Input clutch drum shaft
    -Broken axle or CV joint
    -Badly damaged geartrain or differential
    Outside of checking the fluid level and axles there is not much you can do short of removing the transmission for a teardown to inspect the parts.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: 2000 Grand prix Tranny problem
    could have also blown a gasket which then raised pressure going through the trans cooler line and sent it to it's death.
  6. #6 Re: 2000 Grand prix Tranny problem
    Welland , Ontario
    so the only thing i can do is bring it to a trany shop ?
  7. #7 Re: 2000 Grand prix Tranny problem
    SE Level Member Nsane's Avatar
    Feb 2010
    Rochester,NY
    not a good idea? how many miles are on your car?
  8. #8 Re: 2000 Grand prix Tranny problem
    Welland , Ontario
    249000 kms
  1. 2000 grand prix gt Interior lamps problem
    By rainlake in forum General Tech Discussion
    Last Post: 06-01-2010, 04:34 PM
  2. 2000 grand prix traction control problem
    By marckub203 in forum Introductions/Noob Questions
    Last Post: 08-19-2009, 10:02 PM
  3. 2000 4T65E HD tranny in a 1998 GTP with no problem in swap......but!!
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2009, 10:53 AM
