Thread: 2000 GTP not shifting from second to third
Results 1 to 10 of 10
  1. #1 2000 GTP not shifting from second to third
    Nov 2010
    North Carolina
    I drove my wife's car last night and discovered that the problem she had told me about seems more serious than she indicated. The car will start out in first gear just fine and then shift to second, but remains in second-- it will not shift to third no matter how high the RPM's are.
    I'm going outside this morning to verify the fluid levels are correct.
    I do not know if it matters, but the button on the left side of the shifter (performance shifter button?) appears to have been broken inside the shifter housing----it just fell off into the floor 2 weeks ago.
    Is there something I can do as a do-it-yourselfer to fix or at least further diagnose the problem?
  2. #2 Re: 2000 GTP not shifting from second to third
    Feb 2010
    Earth
    My car's tranny has been having the exact same issue (along with many others) according to trannyman, it's either the third gear sprag or sprocket assembly which unfortunately requires a rebuild.
    Mine's being rebuilt as we speak and I can't wait to get it back
  3. #3 Re: 2000 GTP not shifting from second to third
    Nov 2010
    Ohio
    I lost 4th gear in my GT and was running about 1000 rpms higher than normal on the highway. Only fix was a rebuild ~$2500.
  4. #4 Re: 2000 GTP not shifting from second to third
    Nov 2010
    North Carolina
    It is in the shop as of yesterday afternoon. I'll update after I hear the estimate.
    BTW-- The fluid was brown and smelled burnt.
  5. #5 Re: 2000 GTP not shifting from second to third
    Nov 2010
    Ohio
    If it hasn't done too much damage to the internals they can re-use some of the parts in a rebuild which would save you a little money. Unfortunately I waited too long and it all had to be replaced.
  6. #6 Re: 2000 GTP not shifting from second to third
    Quote Originally Posted by sjp 2002 GT View Post
    A hub shaft costs about ~$60 and the gaskets are ~$30, add fluid ~$35. Then labor to lower the subframe and trans to get the side cover off. At this point you should swap the EPC soleniod as well. However a full rebuild isn't necessarily needed.
  7. #7 Re: 2000 GTP not shifting from second to third
    Nov 2010
    North Carolina
    It's in the tranny shop today. I'll let you know the outcome.
    Any idea about the button on the shifter?
  8. #8 Re: 2000 GTP not shifting from second to third
    The button shouldn't be a big deal. If you are stuck in perf or normal mode, the differences in programming aren't enough to make a noticable change. Stock is something like 2-300 rpm.
  9. #9 Re: 2000 GTP not shifting from second to third
    Nov 2010
    North Carolina
    Car was diagnosed with both 3rd and 4th gear out. For 4th gear, teeth on gear were completely shredded. Parts and labor total $1600.00. Should have it back tomorrow evening with a 12 month warranty.
  10. #10 Re: 2000 GTP not shifting from second to third
    Nov 2010
    North Carolina
    Final price..... $1500.00 to rebuild transmission. The splines on the fourth gear shaft/gear mechanism were stripped. The mechanic said that this was probably out for some time before the problem with shifting to third became evident. He said that third was burned out. Anyway, if you're having this problem, plan to spend some bucks. If your car is in good shape, it will be worth it to repair.
  1. 2 to 3 tranny shifting & WOT shifting problems
    By josh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 08:52 PM
  2. shifting from first to second
    By zuk7 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 05-24-2010, 08:09 PM
  3. car not shifting right??
    By Joe m in forum General Tech Discussion
    Last Post: 02-02-2010, 08:50 PM
  4. 2000 GT shifting really hard
    By c002529 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-04-2009, 12:08 AM
