Thread: car won't move in D
Results 1 to 8 of 8
  1. #1 car won't move in D
    Nov 2010
    Indiana
    Hi all,
    A few days ago the alternator went out in my wife's 98 grand prix gt and it died down the street from our house because the battery went dead. I jumpstarted it and when she shifted into drive the car would not move at first, then went into gear and she got it home. I put a new alternator on it 2day along with a new battery and that fixed the charging problem, but now the car won't move at all in Drive. It works fine in reverse and if shifted into 2 or 1 it will move under light throttle. Any ideas what could be wrong? It sounds like something inside the tranny is bad, but it puzzles me that it only happened after the battery went dead.
  2. #2 Re: car won't move in D
    Nov 2010
    Indiana
    I took the car to my work today and put it on the snap on scanner (I work at a toyota dealer). Found no dtcs in system but found during function test that I can make trans shift into every gear but 1st. I'm thinking internal trans issue.
  3. #3 Re: car won't move in D
    Jul 2008
    sumter,south carolina
    sounds like u lost the forward band.
    02 GTP with mods 05 GP for DD
  4. #4 Re: car won't move in D
    let's toast til we die brand121's Avatar
    South Carolina
    sounds like what is going on with mine too, kinda... No Forward Cold
    As for the timing of the alt and trans doing it at the same time, it's not unheard of for things to go wrong at the same time. Last month my fuse box went bad, ignition switch, and I ended up replacing all of my solenoids in the tranny, all at the same time...
    My couch pulls out, but, I don't...
  5. #5 Re: car won't move in D
    Wont move in D or 3 only
    This one... not the one you linked.
  6. #6 Re: car won't move in D
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    Man that sucks
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  7. #7 Re: car won't move in D
    Nov 2010
    Indiana
    Well you guys are right, tab broke off forward band. 2400 dollars later I got the car back now. Drives great now hehe
  8. #8 Re: car won't move in D
    Expensive but necessary, glad you're up and running now.
  1. Time to move on!
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 07-08-2010, 12:18 AM
  2. how hard would it be to move a motor?
    By Poil336 in forum Off Topic Discussion
    Last Post: 06-30-2010, 10:35 PM
  3. It's 2010, let's move on...........
    By Purple Plazma in forum The Rant Forum
    Last Post: 01-16-2010, 06:19 PM
