Thread: trans coolier/shift problem
Results 1 to 15 of 15
  1. #1 trans coolier/shift problem
    Feb 2010
    Flint Michigan
    i am using this trans coolier on my 1998 gtp.
    Hayden Automotive 678 - Hayden Fluid Coolers - Overview - SummitRacing.com
    not sure if the problem was there when i first installed the trans cooler.
    but now i have noticed my trans shifts high, 3 grand each gear when I am just cruising around town. is this normal?
    could the trans coolier be causing this?
    could the trans be to cold and torque lock up not working?
    could drit or grit in trans from having 190,000 miles maybe clogging up trans cooler, increasing presser, and restricting flow?
    could torque converter be going out?
    could trans just be going out?
    also if i floor it WOT it shifts at 5700, is this normal?
    need some feeback dont want to rip off the cooler if thats not the problem.
  2. #2 Re: trans coolier/shift problem
    not sure on the cooler part,
    but 5700-5900 is normal, these is really no power past 5500
  3. #3 Re: trans coolier/shift problem
    Feb 2010
    Flint Michigan
    alright it shifts a 5700 in normal and performance shift.
    I thought performance shift increased shift rpm?
    but any help on the high shift problem while daily driving?
  4. #4 Re: trans coolier/shift problem
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    Did you check your fluid a few times after you installed your cooler?
    Also did you see what color the fluid is while you were installing the cooler?
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  5. #5 Re: trans coolier/shift problem
    Jul 2008
    sumter,south carolina
    i dont think performance shift changes shift points... just increases line pressure for quicker firmer shifts.
    02 GTP with mods 05 GP for DD
  6. #6 Re: trans coolier/shift problem
    Feb 2010
    Flint Michigan
    Yes it checked fluid it was ok, but today I am going to go dex6. 8 quarts right for trans pan drop and filter
  7. #7 Re: trans coolier/shift problem
    Charles City, IA
    yup around that.
    SMGPFC Two Nipple General
  8. #8 Re: trans coolier/shift problem
    Feb 2010
    Flint Michigan
    all right a little update, i did a tranny pan drop and filter change with dex 6, still does the same thing.
    at 70 my rpms are at 2100 if that maters at all.
    but i noticed when i hit the brake to stop the cruise control the car revs up a little, why would it do this now?
  9. #9 Re: trans coolier/shift problem
    Feb 2010
    Flint Michigan
    another update if i let off the gas a little it will shift early, but if i stay on the gas it still climbs to 3,000 rpm then shifts.
  10. #10 Re: trans coolier/shift problem
    Feb 2010
    Flint Michigan
    Help
  11. #11 Re: trans coolier/shift problem
    HUDSON
    I don't know if this will have any relation to the condition you are expieriencing, but the computer will not lock the converter until the trans. temp is above 80 degree.
    I found that out prowling around in the transmission parameters of my tuner program.
    Now, if your trans temp is not high enuff, possibly the computer is delaying shifts to speed the warm up of the engine and transmission, (in theory).
  12. #12 Re: trans coolier/shift problem
    Feb 2010
    Flint Michigan
    Quote Originally Posted by monsterjam5000 View Post
    thats what i was saying in my first post, how would i check that?
  13. #13 Re: trans coolier/shift problem
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    This is normal.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  14. #14 Re: trans coolier/shift problem
    Feb 2010
    Flint Michigan
    is it normal to hit the brake and the rpms jump up?
    still cant find the problem seems like it takes for ever to shift gears.
  15. #15 Re: trans coolier/shift problem
    Feb 2010
    Flint Michigan
    anyone now it shifts at 3500 why is it doing this?
  1. GTP Trans won't shift to 4th after hill
    By SliceTheRice in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-11-2010, 10:37 AM
  2. Trans does not want to shift out of 1st until warm
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2010, 11:45 AM
  3. What Trans Shift Points should I use?
    By Quicklynx in forum PCM Tuning
    Last Post: 10-25-2008, 08:04 PM
  4. shift kit problem.
    By 00pontiac1971 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2008, 06:47 PM
  5. Does the trans need to be dropped to swap out shift solenoids?
    By bminior in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-08-2008, 08:59 AM
