Thread: quick steps to check how bad the chain snapped?
Results 1 to 4 of 4
  1. #1 quick steps to check how bad the chain snapped?
    from the tranny smarts out there(trannyman as well as 3800se and any others), i JUST want to check how bad the chain was broken in my old tranny, but is it something i should be able to do or should i just wait for a few months til i just ship it out to trannyman to get it repaired/rebuilt(opened a savings account just for this). if its doable, please give me tips and instructions to get to the chain, otherwise just let me know its not worth the time and prolly the 'safety' of the trans the way it is now. thanks in advance!!
  2. #2 Re: quick steps to check how bad the chain snapped?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    It is a bit of work to get to the chain. You have to remove the side cover, wiring harness, pump, valve body, then the channel plate/large casting under the valve body, and then you are at the chain and gears. There are quite a few bolts and 10 checkballs that will come rolling out when you take it apart. Make sure the trans is drained before you do this or it is going to make a big mess!
  3. #3 Re: quick steps to check how bad the chain snapped?
    thanks dave, if/when i do get to the chain, are there any torque specs i should know of when i put everything back to together?
  4. #4 Re: quick steps to check how bad the chain snapped?
    Fort Wayne, IN
    Not sure if I put specs on the chain install writeup on here or not, but all the torque specs are on my info page of my website.
  1. Please Help Quick!
    By 2tone bullit in forum General Tech Discussion
    Last Post: 05-22-2008, 07:37 AM
  2. Snapped some UIM gaskets, should I drive?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2008, 05:43 AM
  3. quick questions
    By mexico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2008, 04:13 PM
  4. Quick Q: Torque Converter
    By TommyGloves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2008, 07:06 AM
  5. Help quick
    By evlprx in forum General Tech Discussion
    Last Post: 02-24-2008, 07:16 PM
