Thread: 1st gear sticking
Results 1 to 6 of 6
  1. #1 1st gear sticking
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Ok so here we go. My car is still under warranty for a few more thousand miles. When I start my car it can go one or two ways. Either the car runs fine and I have no problems or the other condition.
    1st gear seems to stick extra long. And when this is happening if I go WoT it hits the rev limiter and I have to let off the throttle and get back into it slowly until it will shift again. Because it is not throwing codes I assume the stealership wont do anything about it but I was wondering if anyone knew what could cause this. The car is an 05 and has 71K on it
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  2. #2 Re: 1st gear sticking
    Trans codes are interesting. Most won't light up a SES and they don't store. You drive the car, get it to do it and scan it before turning the car off. Then you'll have a code if one exists.
    GM did this intentionally so that our cars drive as good as possible...say it's an overheated or swelled part it won't always show...the driveability won't default permanently.
  3. #3 Re: 1st gear sticking
    Jul 2010
    Michigan
    So for us without a scanner it becomes impossible to tell whats wrong and the dealer wins to :-P
    2005 GTP Grey
  4. #4 Re: 1st gear sticking
    Unless you bring a buddy to Autozone. The buddy sits in the car while you ask them to scan the car.
  5. #5 Re: 1st gear sticking
    Jul 2010
    Michigan
    touche! my man touche
    2005 GTP Grey
  6. #6 Re: 1st gear sticking
    Jul 2010
    Michigan
    Well to update I ended up taking it to the dealership caus it was aviting up again. They put me in a free rental car (2010 malibu) and just called said they found nothing wrong... as usual. However, they did say that it is noted and if anything does happen shortly after my warranty expires they will fix it. Atleast I have a resonable dealership
    2005 GTP Grey
  1. 91 gpse ,throttle is sticking
    By mbgpse91 in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-18-2010, 05:18 AM
  2. sticking door handles
    By Pittman06 in forum General Tech Discussion
    Last Post: 01-01-2010, 01:22 PM
  3. Help With Sticking Sun Roof
    By Zilcho in forum General Tech Discussion
    Last Post: 08-21-2009, 06:06 PM
  4. Sunroof Sticking
    By streetsmart in forum General Tech Discussion
    Last Post: 06-27-2009, 01:04 PM
  5. Gas Pedal Sticking
    By J_Man55 in forum General Tech Discussion
    Last Post: 06-29-2008, 09:53 PM
